The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 registered members (agedhorse, Joe W, 52Carl, homer52, 1 invisible), 295 guests, and 3 spiders.
Forums47
Topics116,106
Posts923,234
Members42,338
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
2nd Series bell housing mounting system. #1308031 Sun Apr 21 2019 05:35 PM
Dongray Offline OP
I am installing a 292 with a T5 into my 1950 using a 1956 bell housing and cross member and cant find any pictures on the hardware that fastens the rubber mount together. I have found the rubber mounts for sale but no hardware. If someone could provide some info or some detail on this I would appreciate it.
Dongray
1950 Chevrolet 1/2-Ton 3100
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308033 Sun Apr 21 2019 05:42 PM
Dragsix Offline
How are you attaching the 56 235 bell housing to the 292 block? That bell housing will not bolt directly to a later 292 Chevy block. I wish it did truth be told.
Mike
Re: 2nd Series bell housing mounting system. [Re: Dragsix] #1308034 Sun Apr 21 2019 06:04 PM
Dongray Offline OP
I'm using a newer 1956+ bell housing which directly attaches to the 292 engine and the T 5 transmission.
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308037 Sun Apr 21 2019 06:48 PM
Dragsix Offline
Could you post a photo of your bell housing?
Mike
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308062 Mon Apr 22 2019 12:10 AM
Tommy Offline
Must be using a bell housing for a v8.
Tommy
59 apache 1/2t
261 short stepside
Re: 2nd Series bell housing mounting system. [Re: Dragsix] #1308088 Mon Apr 22 2019 03:44 AM
Dongray Offline OP
Here you go Mike,
The original bell housing is flat where it mates to the crossmember where as this one is angled so in order to use it I will be replacing the crossmember as well. I need to do this because the original bell housing wont mate up to the 292 engine so it is driving me to a couple of modifications.
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308105 Mon Apr 22 2019 11:46 AM
SimS Offline
Dongray;
Here is a picture of a TriFive passenger car rear mount. Have you thought about using the rear mount on the T5 since you are building cross members?
SimS
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308125 Mon Apr 22 2019 02:37 PM
rfs56trk Offline
The components for the rear mount consist of the upper and lower mount, a 1/2" x 4" NC bolt, a steel sleeve, and a retainer that has a bend over tab. The mounts and the bolts are available through several aftermarket sources, the sleeves and retainers are not. The sleeves could possibly be made from a short piece of pipe, the retainers could also be fabricated.
Fred
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308152 Mon Apr 22 2019 07:25 PM
Tommy Offline
The bell housing in the picture is a for a truck, it only has one bolt holding it to the mount.
Tommy
59 apache 1/2t
261 short stepside
Re: 2nd Series bell housing mounting system. [Re: Dongray] #1308347 Wed Apr 24 2019 02:21 AM
Wrenchbender Ret. Offline
Classic Parts has the complete mount set for that. It has the mounts, bolts, spacers, & lock tab in a kit.
George
1956 Chevy 1/2-Ton Pickup
Page 1 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
