The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members ('54 3600, Skip68, dirtball), 43 guests, and 2 spiders.
Forums47
Topics114,655
Posts909,613
Members41,982
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
235 engine mount plate #1307423
Wed Apr 17 2019 02:46 PM
SLAWNSKI  Offline OP
Eureka IL
I’m working on sealing my new ( to me) 235. I’ve pulled the cam and removed the mount plate ( what I’m calling it) all past gasket gunk is off- lots of old silicone between the front bearing block and the plate and now I think I know why. It appears as if this plate is bent pretty good. If you look at the phots you can see what I mean. I’m assuming the plate needs to be flat but before I go smacking it around ( somebody before me already had) I want to confirm it needs to be flat. I’ve got it mounted in a vice at work and using a beat up ruler to show the gap. Thanks for your help!
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Re: 235 engine mount plate [Re: SLAWNSKI] #1307427
Wed Apr 17 2019 03:11 PM
showkey  Offline
Wausau WI
Think a press would be the tool of choice. Plan an attack...........Then some careful adjustments............
Re: 235 engine mount plate [Re: SLAWNSKI] #1307503
Thu Apr 18 2019 02:03 AM
52Carl  Offline
Virginia
I wouldn't bother trying to fix that. Metal does not just get bent. It also gets stretched. That is hard to undo especially when it is that thick.
I can't picture what would have bent it that severely. Any ideas?
I good used replacement shouldn't be that hard to find
Carl
Re: 235 engine mount plate [Re: SLAWNSKI] #1307514
Thu Apr 18 2019 02:48 AM
delux54panel  Offline
VACAVILLE, CA.
Theres only a very thin paper gasket that seals that plate to the block. Im not sure if the assembly manual recommends gasket sealer or not.
I sent you a P.M.
Re: 235 engine mount plate [Re: SLAWNSKI] #1307525
Thu Apr 18 2019 03:36 AM
2ManyTrucks  Offline
california
Well, if you are going to replace it... nothing to lose by trying to flatten this one
It’s a free learning opportunity
Heat and a hammer, beer optional smile
-s
1430s, 1420, 9430
-2MT
Re: 235 engine mount plate [Re: SLAWNSKI] #1307529
Thu Apr 18 2019 03:58 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
I've got a couple of those plates stashed away from junked engines if you decide you need a replacement. Drop me a PM.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 235 engine mount plate [Re: SLAWNSKI] #1307560
Thu Apr 18 2019 01:06 PM
sstock  Offline
Gig Harbor, WA
Judging by the look of that plate, one hell of a front end collision, I'd check the threads and block too to rule that out.
Re: 235 engine mount plate [Re: SLAWNSKI] #1307580
Thu Apr 18 2019 03:55 PM
Boltergeist
Dellrose, TN
How about a fall from a Mickey Mouse flimsy engine stand with the front of the engine hitting a concrete floor? It wouldn't be the first time a stand designed for a small block V8 and a stovebolt six didn't play well together!
Re: 235 engine mount plate [Re: SLAWNSKI] #1307583
Thu Apr 18 2019 04:04 PM
52Carl  Offline
Virginia
Another possibility is not finding the secret squirrel flush, countersunk, gunk covered screws and trying to pry the plate off with a crow bar.
Re: 235 engine mount plate [Re: SLAWNSKI] #1307587
Thu Apr 18 2019 04:26 PM
Boltergeist
Dellrose, TN
Hmmmmmm- - - - - -"Wreck it Ralph" builds engines?
LOL!
Page 1 of 2 1 2
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
