The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 185 guests, and 4 robots.
Forums50
Topics118,951
Posts952,155
Members43,297
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: 216 Engine Carb Advice
ThreeSixHundred #1307447 Wed Apr 17 2019 07:50 PM
Carburetion specialist
Chris - since you have the electronic whizbang, have you upgraded to an alternator?
We have had lots of customers with "carburetor idle issues" and a ew with no alternator. The generator does not provide a significantly stable voltage at idle. Generally, the problem (running rich) goes away when the engine gets above maybe a 1000 RPM.
Jon.
The most expensive carburetor is the wrong one you attempt to modify
If you truly believe "one size fits all" try walking a mile in your spouse's shoes!
[image]http://www.thecarburetorshop.com/Avatar.jpg[/image]
ThreeSixHundred #1307538 Thu Apr 18 2019 06:41 AM
Hello Jon
Yes I have fitted a modern alternator
Regards Chris
ThreeSixHundred #1307561 Thu Apr 18 2019 01:16 PM
Interesting that this has come up. I was just searching for a w-1. You mentioned that the truck hasn't been run much, so some of the issue may be that it needs to be on the road a little more. The compression check will tell you some good things and most likely ease your mind some on the previous owners rebuild. I am a died in the wool fan of the carter YF. It solved many of my issues with the rochester -b. They have suddenly become a lot more expensive on e-bay though.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My Webshots Album
ThreeSixHundred #1307562 Thu Apr 18 2019 01:20 PM
Chris, NICE truck with all the great original sounds. After watching your vid and reading the above I've no doubt you'll have it all properly sorted very soon. We have many knowledgeable gentlemen here that give good advise. The only thing I'd change on your truck (aside from the fuel pump and perhaps carb) is the air cleaner. I personally like the original oil bath units, either converted to paper filters or just leave em totally original. But, lots of options to get a larger/better filter on your truck.
Good Luck,
RonR
1970 340 Duster
1951 Farmall Super A
ThreeSixHundred #1307564 Thu Apr 18 2019 01:24 PM
Hi Chris,
Different Jon here. If you want to see the work/study on the warped Rochester castings, you might search using "straightening Rochester castings". Based on what I saw, every Rochester B or BC will have a warped casting to one degree or another. There is also some information on the power circuit/power piston and the problems caused by loss of vacuum, inadequate vacuum, etc to that part of the carburetor and the effect it will have on the rich/lean condition.
The Carter I'm using on my 235 does run much leaner and more well mannered than the Rochester did by the way.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
ThreeSixHundred #1307567 Thu Apr 18 2019 02:09 PM
Anyone use a Carter carb on a 261? Thoughts?
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
ThreeSixHundred #1307574 Thu Apr 18 2019 03:02 PM
Boltergeist
Carter was the original equipment carb on Chevy engines for a long time until GM started to build their own carburetors in the early 1950's. I believe a Carter YF for a 258 cubic inch International/AMC/Jeep 6 cylinder engine would be just about perfect for a 261, or maybe the same carb set up for a 300 cubic inch Ford six, which would run slightly leaner than the AMC carb when used on a 261.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
ThreeSixHundred #1307603 Thu Apr 18 2019 07:20 PM
anybody know the last year the w-1 was used?
1946 1-ton Panel
My Webshots Album
ThreeSixHundred #1307608 Thu Apr 18 2019 07:54 PM
1949 - passenger
1950 - truck
ThreeSixHundred #1307618 Thu Apr 18 2019 08:39 PM
Thanks Carbking
1946 1-ton Panel
My Webshots Album
Page 2 of 3 1 2 3
Moderated by  Woogeroo
