The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 149 guests, and 3 robots.
Forums50
Topics118,951
Posts952,155
Members43,297
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 6 1 2 3 4 5 6
Re: Excellent, another radio to play with
2ManyTrucks #1307345 Tue Apr 16 2019 08:54 PM
update on radio fun,
this morning i drove some of the steel chassis innards to the sandblasting / plating shops up in Oakland
started some cleanup work on the tuner unit
used Meguiar's ultimate polish to clean the dial face, i think it turned out very well
some parts had received a good layer of blue paint, i'm going to reuse the plastic part of the escutcheon because the aftermarket replacements don't allow an original dial face to fit.
(i find that in general reproduction plastic escutcheons won't fit most of the parts that need to go into them)
after carefully scraping off the paint and sun damaged parts, i was able to use boiling water to carefully straighten and restore the form of the original plastic
i'll repaint it with a wine/maroon color, it's not original to have paint, but it's in too rough of shape and color anyway
anyone wanting a more precise restoration would either have to work with the aftermarket plastics or use a better matched paint on this one
repainting this part would not require much effort
-s
2ManyTrucks #1307368 Wed Apr 17 2019 12:34 AM
This is quite fascinating to see your work. Have you ever used an ultrasonic bath for this kind of work?
1951 1 Ton Completed
truckernix #1307424 Wed Apr 17 2019 02:51 PM
i don't have any cleaning apparatus, so far i have been using evapo-rust, soap, rubbing alcohol and manual labor.
i have though about getting some sort of small bench top device, would ultrasonic baths clean off surface rust? is it like a fancy rock tumbler?
i will go google this, i've thought about it before and i do have a couple dozen screws that need cleaning or replacement
any recommendations welcome
thanks
-s
2ManyTrucks #1307437 Wed Apr 17 2019 05:42 PM
I haven't used one either. I think jewelers use them and hobby stores are selling them these days. That product Evaporust is amazing stuff. It attacks rust and leaves the other metals alone.
2ManyTrucks #1307518 Thu Apr 18 2019 02:55 AM
I did some googling, and watched some YouTube about these ultrasonic cleaners, some folks swear they can remove rust with reasonable results with the correct cleaning solution
Based on what I saw on YouTube it should be a useful tool for cleaning dirt and grease at the very least, so I ordered one from amazon for under 100
It will arrive in a few days and I’ll post how well this China machine does.
-s
2ManyTrucks #1307633 Thu Apr 18 2019 10:40 PM
progress... refurbishing the power/volume/tone switch
took it apart, cleaned all the bits, put a bit of fresh zinc onto some of the parts, re-assembled
the brass is stained because the oxidization reduced the alloy to just copper at the surface in some places
not sure the best way to make it look brass again, if i had a very fine wire brush i could probably polish until i'm at brass again
but it's in the bottom of the threads
suggestions?
-s
2ManyTrucks #1307654 Fri Apr 19 2019 01:58 AM
Maybe try Flitz polish on the brass? Will take some work to get down into the threads, but it works well to polish brass (among other things). I first used it when I was working as an electronics tech in grad school, to polish the internals (brass tubing) of an electron beam column in what would now be considered an antique scanning electron beam microscope. It was the only thing that allowed us to keep the internal structure clean enough to keep the beam focused, FWIW. Basically removes oxidation and leaves no significant residue if wiped off thoroughly. We used isopropyl alcohol for that. Nothing very exotic...
2ManyTrucks #1307923 Sat Apr 20 2019 08:54 PM
i found some compounding paste and used a fine steel wire brush, the brass got reasonably better
also i got an ultrasonic cleaner on amazon, gonna test it out soon on some intricate tuner unit parts
in the mean while, please enjoy the tuner coil before and after photos smile
the center double coil halves had broken free from each they should be glued together so they can't move
i ended up rewinding the coil after all the brittle gyptal flaked off and the windings came loose
-s
2ManyTrucks #1307947 Sat Apr 20 2019 11:49 PM
the ultrasonic cleaner...
it works okay, but it won't remove everything
it did a reasonable job of this complicated part in the tuner unit, photos attached
i used only water and a bit of shampoo in the cleaning bath
i have two of this particular assembly, the other one is brighter and better looking, probably will go with the other one
maybe i should try baking soda or some stronger chemicals in the bath, i heard folks use evapo-rust directly in the cleaning bath
-s
2ManyTrucks #1307951 Sun Apr 21 2019 12:42 AM
By my experience, ultrasonic cleaners work great with weak solvents (isopropyl alcohol, methanol, that type of thing) for degreasing. Detergent solutions are fine, but with anything that is more aggressive, be cautious. They start etching pretty fast with mild to stronger acids, like evapo-rust. If you try those, go with short cleaning times initially, until you see how a particular solvent behaves with the parts that are being cleaned.
Moderated by  truckernix
