The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (Jimmie D, 1 invisible), 224 guests, and 3 robots.
Forums47
Topics117,681
Posts941,457
Members43,024
Most Online1,229
Jan 21st, 2020
Image Posting Policy
tailgate chain hole location in pocket
#1307463 Wed Apr 17 2019 09:20 PM
apba12m Offline OP
since my pockets are new and did not come drilled for the chain mount what is the location dimension to drill the hole? also was it a square hole...Lou
1951 chevy 3100 short bed frame off resto.
Re: tailgate chain hole location in pocket
apba12m #1307491 Thu Apr 18 2019 01:13 AM
How do you drill a square hole??
49 3100 #1307509 Thu Apr 18 2019 02:34 AM
With a square drill bit, of course. grin
Just drill a round one and file the corners out. You can just drive the square head (carriage style) bolt in once you get close.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
apba12m #1307523 Thu Apr 18 2019 03:27 AM
I do my squares the old fashioned way, with a triangle file (because a square file will leave the corners over 90)
I filed about 2 dozen squares for the metal strips in the box floor
I started with a square file, but it soon became apparent that the reason triangle files exist is because they make square hole much easier
-s
Harold46 #1307531 Thu Apr 18 2019 05:23 AM
Originally Posted by Harold46
Those are actually driver bits for square recess (Robertson) screws. A #2 square bit is less than 1/8 inch across, so wouldn't make a very big square hole if used in a hammer drill with rotation turned off. But if a guy made a similar tool in the right size, that would make swageing or broaching a square hole a piece of cake.
