The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
22 registered members (1046 chase, bobpos1, 49nut, 47fivewindow, 78buckshot, 1 invisible), 368 guests, and 3 spiders.
Forums48
Topics117,052
Posts935,189
Members42,762
Most Online1,027
Dec 27th, 2019
Image Posting Policy
Page 1 of 3 1 2 3
Solenoid gone bad? #1307296 Tue Apr 16 2019 02:43 PM
I
idaho39 Offline OP
I have a 1955 Chevy 235 engine and when I turn the ignition to start the car ,,the starter hesitates and then takes hold ,some times ,many times right after another before it engages and stays engaged long enough to start the engine .. I am asking how to determine which of the two are faulty before I buy one or the other .
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307299 Tue Apr 16 2019 02:59 PM
beltfed Offline
It really doesn’t matter if you’ve yet to pull them off the motor. They come off as a pair. Once off it becomes easy to troubleshoot the two. Just make sure your not going down a rabbit hole. I had the same issue this spring. After way too much work, found the ignition switch had burnt contacts.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307301 Tue Apr 16 2019 03:04 PM
I
idaho39 Offline OP
So, I take the solenoid off the starter leaving the starter connected up to the motor and then check the solenoid and relay for continuity of each to determine which one is bad.?
.I will take a look at the ignition switch first..
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307328 Tue Apr 16 2019 06:33 PM
Wrenchbender Ret. Offline
Does the starter spin but not turn the engine or does it click & not turn the starter?
George
1956 Chevy 1/2-Ton Pickup
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307334 Tue Apr 16 2019 07:19 PM
I
idaho39 Offline OP
The starter does not click .It spins .but only after it starts to connect to the fly wheel.. after a few tries it takes hold enough to turn the engine over and it starts
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307340 Tue Apr 16 2019 07:58 PM
V
VEW Offline
Sounds like you have a weak spring....assuming all your connections are good.
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307342 Tue Apr 16 2019 08:05 PM
bartamos Offline
You don't have a starter relay and a solenoid. They are the same thing. You probably have a bad/weak battery. When it does that, jump it and see what happens. There are TWO models in 1955. 55.1 and 55.2. Which one do you have?
The starter is not supposed to spin until it engages the flywheel. So it's working correctly.
Don't mix your guess in with symptoms. Report your result after jumping. Then we can move forward with next test. Be sure you jump it with a good battery and check your battery posts and cable clamps. Take off and clean really good. Check cable and wires to starter. Check carefully.
Tell us anything you have done electrically lately with wires, battery, cables, solenoid, ignition switch...........
Don't remove starter or solenoid. That's later. Use a volt meter on battery. Touch only the posts and read. Then touch only the clamps and read. looking for 12.6V.
The only relay you have is a horn relay which also acts as a hot terminal block, sometimes, and may look like it's energizing starter.
Fords have actual starter relays.
Generally: a relay has no external mechanical linkage and a solenoid does. Their electrics operate basically the same. So confusion results.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307348 Tue Apr 16 2019 10:29 PM
I
idaho39 Offline OP
bartamos. thanks for the help with the wiring ,,it is in and works fine except I might have gotten the wrong oil temp sender. that can wait ,,as now I want to fix the starting problem I have and had before I wired in the turn signals thru the ignition
I just went out and read my battery amps and it is at 12.55 ,,I put my slow charger on it and after it charges up to 12.6 then I will check the cables to the starter ..
I have a car motor 55 Belair ,,guess you were talking about the two years of PickUp styles with the 55.1 and 55.2 ..if not then you'll have to enlighten me..
Ok, glad I only have one relay or solenoid.. After getting all the wiring put in and tested to work properly ,,I then charged the battery to full and it is down some to 12.55 from a full 12.6..
Thats all I can come up with for now about any changes ,and like I said it did this same thing last June when I drove it last,, I do have a good battery to jump the one in the car ,,but need a helper and my son flew back home last Saturday ..
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307353 Tue Apr 16 2019 11:10 PM
bartamos Offline
OK good. 12.55 is close enough. It could still be bad because they show 12.6 at static (no load) then break down under the extreme load of starter.
Yes, I was speaking of 55.1 55.2 trucks. Wanted to look at the correct schematic in case there were changes. If a car motor has something different than what I said, I don't know it.
I still say battery or wires/cables/terminals/clamps/connections/corrosion/, lead/copper sulfate.... The jump from another battery is still necessary. A helper is not mandatory. Pull other vehicle close, hook up cables and start motor. Stop motor, get out and disconnect. The posts and clamps MUST be thoroughly cleaned. The idea is to see if starter suddenly acts normal whether it starts the motor or not.
You can also take the battery to two different places. They will put under load and test. Don't trust one place/machine/operator. O'Reilly's, Autozone, etc do it for free. In or out of the vehicle.
So many times I have seen myself and others struggle when it was the battery or it's connections. It will fool you. So we must be 100% sure before blaming something else. This includes battery ground to the motor, ground to body and frame.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307372 Wed Apr 17 2019 01:23 AM
truckernix Offline
I think you might get a further hint if you turn on the dash lights before hitting the starter. If the lights blink or go out, you have a connection problem or weak battery.
1951 1 Ton Completed
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307382 Wed Apr 17 2019 02:05 AM
It sounds like you have a bad starter drive. It has a one way clutch in it. When it gets old & worn the clutch slips & it doesn't turn the flywheel. A starter shop or some old time mechanics can change the drive but its probably the same cost to get a reman starter.
George
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307392 Wed Apr 17 2019 04:20 AM
bartamos Offline
It does sound like solenoid does not stay engaged. If not battery/connections, I would go along with the spring as Victor said/starter drive as you say or entire solenoid replace. Can't hear, see or observe. Trying to read hard on his explanation. Without the clicking, I know you guys are thinking starter drive, not solenoid electro magnet strength/coils because it always spins. I focused on first post saying starter hesitates and thought battery/connections. I just suggested what I would do to prove to myself it's not the battery with something easy, like cleaning and jumping.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307438 Wed Apr 17 2019 06:13 PM
I
idaho39 Offline OP
After checking for voltage drop at the starter and found none I preceded on with the next step and so I hooked up the jumper cables to my truck battery which read a full 12 +volts to the battery in the other vehicle that still reads 12.55 volts .. same thing as before ,..I seen no drop in dash lights , .
So now tomorrow morninng I have a re-manufactured starter along with a new solenoid coming to the auto parts store .
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307449 Wed Apr 17 2019 08:04 PM
bartamos Offline
I'm going to take a wild guess here. You have a 1939 Chevy car, either coup or sedan. It has a 1955 Chevy car motor in it.
Let us know how the new starter works. A road trip is on your future.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307452 Wed Apr 17 2019 08:27 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
He was trying very hard not to tell us he was working on a car. He almost succeeded.🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307474 Wed Apr 17 2019 11:20 PM
bartamos Offline
That's OK. Nothing in this posts is car specific really. 235 and wiring is basically the same. But watch it buster!
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307477 Wed Apr 17 2019 11:38 PM
I
idaho39 Offline OP
I know ,,but but but .. you guys on here are so knowlegable and helpful ..maybe I should move on and not have the temptation to ask for help . thx all who replied about this .
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307479 Thu Apr 18 2019 12:05 AM
bartamos Offline
Tiny will be your friend.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307499 Thu Apr 18 2019 01:45 AM
Stick around. Cars have Stovebolt engines too. There is a great bunch of guys on this website all willing to help.
George
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307551 Thu Apr 18 2019 12:25 PM
I
idaho39 Offline OP
Thx to all of you who replied to my posting , My first old stove bolt was a 39 I bought for $50 ..when I towed it home at the age of 19 ,the clutch was stuck to the preasure plate and to get it out I had to drop the rear end ,,inclosed drive line .. I have photos and could post them in the spoon of it after I got it running good and spray painted it with grey primer paint ,,and maybe I will some day , if any one is interested to see them.. the winter of 64 I took the wife to her mothers as she was about to bare our first child as it was closer to the hospital .. the old stove bolt froze up and busted the block and I sold it for $35 .. So this vehicle I have now is a desire to own another some 54 years later..
The next step was pull the starter,,, soon as I did I found at least one of the culprits,, the gear went round and round .. Went to town and bought a new starter and relay ,,put them together and installed them and now the starter keeps on turning the fly wheel until gas gets to the carb and the motor starts .. not sure if the relay was bad and didnt want to take a chance on it ..so I might just rebuild the old starter as it Delco Remy and kinda want that back in the ______ as it is old stock
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307598 Thu Apr 18 2019 06:25 PM
Rusty Rod Offline
Moderator - The Electrical Bay and Rocky Mountain Bolters
So, you are saying that the problem is solved? If the gear is round, what shape are the flywheel teefs?
Another quality post.
Real Trucks Rattle
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307617 Thu Apr 18 2019 08:39 PM
bartamos Offline
Good job on your Chevy X, Area 51 vehicle. Probably feels good to have that sorted.
Re: How do you determine if it is a Starter Relay Or Solemoid gone bad? [Re: idaho39] #1307621 Thu Apr 18 2019 09:17 PM
I
idaho39 Offline OP
Rusty Rod. .I meant that the gear of the old starter just freely turned round and round ,,which it should not do that ..as for the teeth on the flywheel? not bad at all very little wear . and it sounds good when I hit the starter as to a good solid grab ..
bartamos,, yes my Chevy X and me are getting along quite nice today ..thank you
Oh ! you ask whats next? well , I have dual carbs and after I get insurance on it to drive on the streets ,I want to take it to old school guy I have met who works on old carbruators .
What if I take my Chevy X stove bolt carbs to the Engine Shop ? They like figering things out there too,,don't they?? smile
Re: Solenoid gone bad? [Re: idaho39] #1307625 Thu Apr 18 2019 09:26 PM
Enjoy pushing the envelope do ya? You have been invited in the past to discuss your Chevy X in the Greasy Spoon Forum. Personally I don’t subscribe to the theory that because it has a inline 6 in the car, it fits the criteria to be included in a “Truck” site. It’s my opinion and I’m entitled to it!
nanner
Re: Solenoid gone bad? [Re: idaho39] #1307626 Thu Apr 18 2019 09:30 PM
bartamos Offline
You can ask about the carbs for sure. Many folks have twin carbs.
Re: Solenoid gone bad? [Re: idaho39] #1307636 Thu Apr 18 2019 10:57 PM
I
idaho39 Offline OP
The truth of the matter is I am breaking the rules even if I call my car Chevy X ..If any of you post questions about your trucks in the spoon as for help ,,It gets moved to what ever the problem is ,, engine shop ,,electrical .drive line ect ect ..that is what is supposed to happen ,,that is the rules ,,the forum was built for trucks ,,and I am happy for all of you ,, great forum not cluddered up with all sorts of other vehicles ,, I was stepping over the line a bit.
No hard feelings against any of you ,, thanks again all of you for befriend me ,, I could stay and ask questions about my 71 Cheyenne as it is under the rules ,,but I have none about it ,, I donated when I first signed into this forum and have gotten every bit of its worth back and then some .. I have recieved more than I contributed ,,again I just wanted to say that me leaving is not because any one of you..
Idaho 39
Re: Solenoid gone bad? [Re: idaho39] #1307645 Fri Apr 19 2019 01:16 AM
52Carl Offline
Drive the X to Homecoming and I'll bet there will be a swarm of truck guys around it. Personally, I consider the original engines of these old trucks to be the most fascinating aspect of the deal.
Page 1 of 3 1 2 3
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
