The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (52 Blue), 274 guests, and 3 spiders.
Forums48
Topics116,172
Posts923,798
Members42,360
Most Online940
Apr 5th, 2017
Image Posting Policy
URGENT! cannister style oil filter help for 66 C10 V8 283 #1307101 Sun Apr 14 2019 09:48 PM
JFBerg713 Offline OP
I had this truck about 3 weeks. I am changing the oil and it has the old style original cannister style oil filter. I am having trouble seeding the rubber gasket. the gasket seems slightly too big for the middle section and too small for the outer ring. I bought and adapter thinking i would try that and I am having the same major oil leaking from the sides. Is there some trick to getting the rubber gasket to seed correctly? The leak is not a small leak.
Any help would be great.
JB
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307103 Sun Apr 14 2019 10:15 PM
Hotrod Lincoln Offline
Boltergeist
"Seeding"? Are you trying to grow gaskets? Here's the problem- - - - -you have part of an adapter for a spin-on type filter, not the complete conversion piece, and none of the pierces needed to position the canister-type filter housing with the small square O ring correctly. Pick one style or the other- - - - -right now you're not equipped to run any kind of filter at all.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307107 Sun Apr 14 2019 10:43 PM
So how was the cannister oil filter on there? All i did was take it off replace the filament and trying to put it back on...
JB
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307108 Sun Apr 14 2019 10:44 PM
All I did was take the old cannister filter off... this was the setup already on the truck...
JB
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307109 Sun Apr 14 2019 10:49 PM
Boltergeist
Here's the part you need to use the canister filter. Copy the link quickly before it gets deleted by one of the moderators.
https://www.ebay.com/itm/55-67-CHEVROLET-V8S-OILFILTER-CANISTER-ADAPTER-OEM-USED-RE8/362608073563?hash=item546d201b5b:g:mSsAAOSwZVpcmiOa
The part that's on there now is part of an adapter for a spin-on filter, without enough bits and pieces to make it work. Someone must have spent a LOT of time getting the big O ring positioned just right to keep it from leaking without having the guide plate in place.
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307110 Sun Apr 14 2019 10:53 PM
ok.. so buying that piece... where does the Oring fit on that piece?
Would buying a adapter kit for a new style spin on filter be better?
What would I have buy to make a conversion kit work?
Thanks for your help, just trying to think thru options
JB
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307112 Sun Apr 14 2019 11:01 PM
Boltergeist
The O ring fits around the outside of the part in the auction- - - -there's about a 1/8" gap between it and the biggest machined ring in the block. With the adapter that's on there now, it might be possible to find a spin-on filter with a seal ring that fits the inner machined surface, but most conversion adapters have their own gasket surface built in. Search "oil filter conversion adapter" on Ebay to see a bunch of them listed.
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307119 Sun Apr 14 2019 11:39 PM
Any chance you might know what adapter that is on there?
JB
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307218 Mon Apr 15 2019 09:31 PM
Boltergeist
I believe back in the dark ages there was a spin-on filter with a gasket that fit the inner machined surface on the block. You might try checking a filter manufacturer's website like WIX to find one with the right thread and gasket diameter for that application. I'd rather spend a few bucks and get an adapter for a filter that's more commonly available.
Re: URGENT! cannister style oil filter help for 66 C10 V8 283 [Re: JFBerg713] #1307221 Mon Apr 15 2019 10:45 PM
bartamos Offline
Yes, get all new. Start over. Plenty of brand choices and videos on internet. Spin on is the only way to go.
I'm away on an ego trip. Will be back on Feb 30.
Moderated by  Hambone, sixtyfive c-10
Powered by UBB.threads™ PHP Forum Software 7.7.3
