The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (honk1e, archburycontrol, Hotrod Lincoln, 3 invisible), 310 guests, and 3 spiders.
Forums47
Topics115,749
Posts919,904
Members42,330
Most Online940
Apr 5th, 2017
Image Posting Policy
1946 1/2 ton S10 Rear end #1305443 Sun Mar 31 2019 05:01 PM
Step42368 Offline OP
Bird's '46 Chevy Truck
I'm putting a S10 rear end in my '46 truck...i want to keep using my 6 lug Artillery wheels ..what are the best 5 lug to 6 lug conversion plates seems to be a lot of choices so i'm hoping to find experience on this site
Re: 1946 1/2 ton S10 Rear end [Re: Step42368] #1305585 Mon Apr 01 2019 06:42 PM
coilover Offline
Most use the 6 lug S10 4wd or the Colorado/Canyon 6 lug. The early Colorado's had drum brakes and later ones disc brakes.
Evan
Re: 1946 1/2 ton S10 Rear end [Re: Step42368] #1305861 Thu Apr 04 2019 12:11 AM
Hotrod Lincoln Online
Boltergeist
There are no "best" conversion plates- - - -only "bad' and "downright deadly"!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 1946 1/2 ton S10 Rear end [Re: coilover] #1305982 Thu Apr 04 2019 11:45 PM
thanks for all the info
Re: 1946 1/2 ton S10 Rear end [Re: Step42368] #1306171 Sat Apr 06 2019 02:32 AM
EdPruss Offline
4wd S-10 and GMC clones have rear axles slightly wider(2" each side I think) which should look better, too.
Ed
Re: 1946 1/2 ton S10 Rear end [Re: Step42368] #1307212 Mon Apr 15 2019 07:16 PM
found out there is lots more mods to have to be done that I can't do myself so i have gone back to changing the gears to 3:55 . I bought the gears and the install kit so i can take it out myself and just have to hire a rear end man to actually install the gears so i can put it all back together
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.7.3
