The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (51Craig1Ton, edwardsss, JD1, CATMAN, jorb, 1 invisible), 323 guests, and 3 spiders.
Forums47
Topics115,012
Posts912,547
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Will mice build without flywheel covers installed? #1307193
Mon Apr 15 2019 04:01 PM
wrenchguy  Offline OP
NW Indiana
After 2 weeks of it sitting i got mice in there again. I plugged the timing hole 3 weeks ago. Will they build without the tin covers? What would be wrong running without them?
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307195
Mon Apr 15 2019 04:22 PM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
I'd suggest installing a large quantity of D-Con- - - - -or a cat! Mice can get into some incredibly small spaces to set up housekeeping, including air cleaners, mufflers and tailpipes!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307196
Mon Apr 15 2019 05:05 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307197
Mon Apr 15 2019 05:11 PM
Justhorsenround  Online
Grease Monkey
El Reno, Okla
Once they have been there the odor tells the ones that follow “hey come on in” and the new mouse condo gets started. You need a hungry barn/garage cat or two. D-Con placed near every opening where mouse traffic occurs. Drive it more often.
drive
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307199
Mon Apr 15 2019 05:13 PM
69Cuda  Offline
Big Bolt Forum Moderator
Seattle, Wa.
running without the covers on the clutch area will allow a piece of gravel or anything else bouncing along the road to possibly get up in there.... I know, that is very unlikely but, it is even less unlikely with the covers on there.
Also, if you are rolling around under your truck with it running, you could get fingers or clothing sucked in there with out the covers on.
That said, I got the bottom one off on my 58, and could not get it to slide back in (trans mounts have deteriorated and settled, or the front of the engine is too low, I think) anyway, I have been running it for a couple years without it back on.
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
Re: Will mice build without flywheel covers installed? [Re: Hotrod Lincoln] #1307370
Wed Apr 17 2019 01:09 AM
52Carl  Offline
Virginia
I am all for installing D-Con, but won't installing a cat make a big bloody mess? I will try it and get back to you later. Now where'd that kitty cat get off to?
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307432
Wed Apr 17 2019 04:13 PM
Red 49 Truck  Offline
Mississippi U.S.A.
I got a 1951 3600 from a friend that had been sitting by the road in the weeds. Got it home and in the shop where I could get under it. It had no cover on the clutch and was FULL of mice nest. The breather was also full and anywhere else you could think of. Took a while to get everything clear but after cleaning it all clean it ran very good. Using the 1955 235 in my 1949 now. With a clutch cover on it!!!.. Hope this helps.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307495
Thu Apr 18 2019 01:27 AM
NW Indiana
Thanks 4 that answer Red. With the timing hole plugged and covers on, what about the clutch bearing fork??? I can't see putting covers on if they're gonna get in anyway.
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1307504
Thu Apr 18 2019 02:04 AM
2ManyTrucks  Offline
california
Yeah I had the same problem, I looked all over if there was a clutch fork boot for the AD 47-53 trucks, and to the best of my research there is no factory boot, so I made one from a tire tube, it’s two big ovals that are held together with copper wire as staples, one slips inside the housing the other sits outside the housing, both tight on the fork
There is a chance the 60s trucks boot could work with modification.
But without a boot, mine will build a new nest in there.
-s
1430s, 1420, 9430
-2MT
Re: Will mice build without flywheel covers installed? [Re: 52Carl] #1307521
Thu Apr 18 2019 03:14 AM
Boltergeist
Dellrose, TN
I saw what was left of a cat that was sitting on top of a Pontiac straight 8 engine one cold winter morning when the owner started it. After the cat got zapped by several spark plugs it jumped right into the fan and knocked the belt off in the process of getting turned into hairy hamburger!
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1309267
Thu May 02 2019 03:02 PM
Mississippi U.S.A.
I don't have a clutch fork cover on mine, I do have one just never put it on. My truck stays in the shop now and I haven't seen any mouse but I'm sure they would get in if they found a hole to get in. I think Hot Rod has the best idea. Decon!!!
Re: Will mice build without flywheel covers installed? [Re: wrenchguy] #1311591
Thu May 23 2019 03:44 AM
glenns towing  Offline
Pittsburgh Pennsylvania
I found this little surprise under a car I tow out of a guys yard that been sitting about 2 years. I guess he got to fat for the exit.. lol
Page 1 of 2 1 2
Moderated by  SWEET
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
