The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (59 fleet, 55 SHAKER, 5 Window 9434, 66flea, dhjmd, AKJohn, 2 invisible), 137 guests, and 3 robots.
Forums50
Topics119,455
Posts956,444
Members43,405
Most Online1,229
Jan 21st, 2020
Image Posting Policy
side window work on a 62
#1306828 Fri Apr 12 2019 02:13 PM
I don't seem to get on here much these days though I still drive my 61 GMC half ton, but again I find myself working on a friend's 62 half ton chev. this time he told me his glass wasn't staying rolled up good and he thought it needed new channels. I ordered a set and when I got the truck over here it seems they are in good shape having been replaced when it was restord. I found several bolts missing that hold the regulator assembly in the door.I'm hoping putting that back will fix it as I dread trying to get the wing window side out just to change what looks like good felt channels.it probably wouldn't help his problem. though the passenger side wing doesn't open and I may very well have to work on it
Re: side window work on a 62
Skelflyer #1306833 Fri Apr 12 2019 03:12 PM
Skelflyer: see this link below. We covered this a few months back on the AD trucks. I’m guessing your problem involves the same part, although I can’t be sure the PN would be the same on a 62. Good luck, Dave
https://www.stovebolt.com/ubbthread...48-bad-window-regulator.html#Post1293386
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Skelflyer #1306944 Sat Apr 13 2019 02:31 PM
Thank you, I don't believe the spring is broken on this one- I had it diss connected from the window and it definitely has tension on the arm. but very worn I know. if I end up needing to replace the unit- I'm thinking I'd have to remove the front window channel along with the wing window to get the mechanism out. is that correct? also I have used several parts from LMC and while most have been serviceable I can't say that some weer near OEM quality.is there a better source for something like the window regulator mechanism?
Skelflyer #1306963 Sat Apr 13 2019 05:12 PM
Used window regulators will work. May need to recondition or use 2 to make 1, but there is plenty of inventory. I do believe you will have to remove glass and vent window before regulator. At least, you may be happier to remove so you dont scratch or break anything. Not real hard to remove to glass and vent window.
HB
1966 Chevrolet K-10
Flappy Fenders
More pictures on Photobucket
1962 Chevrolet C10
Moderated by  Hambone
