The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (DennisM, 5 Window 9434, BC59, ASU, 2 invisible), 264 guests, and 2 spiders.
Forums47
Topics114,621
Posts909,404
Members41,973
Most Online940
Apr 5th, 2017
Image Posting Policy
2001 chevy dash light troubles #1305360
Sun Mar 31 2019 01:38 AM
GIJOE298  Offline OP
North Dakota
I have 2001 Chevy Silverado 1500, noticed the dash lights were out, not the fuse, replaced the light switch problem solved...for a while then the dash lights were out again. looked at the old switch and found the plastic piece the rheostat the allows to dim the dash lites was broken. got a new switch put it together fired everything up and saw a puff of smoke and the rheostat is broken again. Has anyone else had this problem? no new aftermarket products, dash is completely stock. sure could use some help with this one.
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1306949
Sat Apr 13 2019 03:29 PM
Spartan  Offline
ID
I have similar problem in my GMC, 99 1500, same body style as the 01.. Mine is just the message center display and the PRND12 and Odometer that light up intermittently. I read something about there being a weak solder joint somewhere it the gauge cluster. But I haven't dug into mine yet.
Hoka Hey!
Spartan
1959 Chevy Spartan 100 "Battle Wagon"
2008 Buell Lightning "War Horse"
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1306954
Sat Apr 13 2019 04:14 PM
Justhorsenround  Online
Grease Monkey
El Reno, Okla
Guys, just a note. This forum is a Swap Meet Forum to be used for the sale/wanted of late model and nonGM stuff. It is not a question and answer garage forum. Questions related to cars/trucks newer than 1972 are accepted with open arms in the Greasy Spoon Forum. Thanks
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1306965
Sat Apr 13 2019 05:44 PM
Spartan  Offline
ID
Thanks Martin,
I didnt even notice where it was. I saw something that had to do with my truck and I immediately got interested. Can you move this so we can hopefully get some answers?
Hoka Hey!
Spartan
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1307135
Mon Apr 15 2019 12:53 AM
Grease Monkey
El Reno, Okla
I can’t move it. I asked a Global Moderator to move the thread to the Spoon.
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1307963
Sun Apr 21 2019 02:08 AM
GIJOE298  Offline OP
North Dakota
Martin, sorry for the trouble. I saw newer GM and thought that would be a good place to toss this question out there. Should have read a little further.
Spartan, thanks for the feed back, think I figured it out, had to go thru 3 bad new out of the box Chinese switch before I found one that worked past the first hook up. Of course reviewed all the wiring first thinking there was some kind of power surge somewhere. Turned out to be just poor replacement part workmanship.
thanks to all.
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1307967
Sun Apr 21 2019 02:25 AM
Grease Monkey
El Reno, Okla
Chinese parts not working right the first time? Who would’ve thunk it! 😁
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1308596
Fri Apr 26 2019 12:03 AM
Woogeroo  Offline
Socket Breaker
Tool Box
for your information, chevy truck forums for the newer stuff:
chevytalk.org
fullsizechevy.com
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1309436
Fri May 03 2019 10:06 PM
GIJOE298  Offline OP
North Dakota
Woogeroo,
thanks for the info. Already found answers to a couple other questions I had.
Re: 2001 chevy dash light troubles [Re: GIJOE298] #1310199
Thu May 09 2019 11:17 PM
Woogeroo  Offline
Socket Breaker
Tool Box
wonderful, glad I could help.
-Woog
Moderated by  Bouncer, Justhorsenround, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
