The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (FinnBolt, CrowbarBob), 122 guests, and 3 robots.
Forums47
Topics117,813
Posts942,682
Members43,047
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Timing lights
#1306206 Sat Apr 06 2019 04:00 PM
MikeE Offline OP
Has anyone used the Innova 5568 timing light on a 6V system? Did it work? Is there any secret to make it function?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
My Webshots Album
Re: Timing lights
MikeE #1306210 Sat Apr 06 2019 04:57 PM
ace skiver
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
Re: Timing lights
MikeE #1306212 Sat Apr 06 2019 05:10 PM
Housekeeping (Moderator) Making a Stovebolt Bed Forum
The inductive pickup will definitely work. Spark plug wire voltage is essentially the same on 6V and 12V systems, around 20,000V.
The issue is the display, which Innova says needs between 10 and 12V. The solution is to use a separate 12V battery to power the light.
From Innova's site:
Does my timing light work on 6V systems?
Your timing light may be used on vehicles with 6-volt electrical systems by using the following connection procedure: 12-volt automotive battery required.
1. Connect the RED battery clip to the positive (+) terminal of a 12-volt battery.
2. Connect the BLACK battery clip to the negative (-) terminal of a 12-volt battery.
3. Using a length of 18AWG jumper wire, ground the negative (-) terminal of the 12-volt battery to a known-good ground on the vehicle under test.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Re: Timing lights
MikeE #1306216 Sat Apr 06 2019 05:29 PM
Shop Clutterist
I won't buy an Innova product. I have an Innova OBD II reader. It doesn't read all the codes on newer cars as the software has changed. I tried to update the software but they don't support it. They want me to buy a new reader. The rep on the phone gave me a lot of BS. frown
Gord
1954 1/2 ton 235 4 speed
Re: Timing lights
MikeE #1306228 Sat Apr 06 2019 09:19 PM
MikeE Offline OP
I hooked it up to a 12v battery and the display for the volt meter worked fine and I even had a reading for dwell. But no tach or timing light flash.
1946 1-ton Panel
My Webshots Album
Re: Timing lights
MikeE #1306229 Sat Apr 06 2019 09:26 PM
The question I have is did the volt meter read the voltage of the 12v battery or the 6v? The inductive pickup should work when clipped around a plug wire to make the timing light flash. Have you tried it on a 12V vehicle? If it doesn't work there, maybe it's just pooched.
Re: Timing lights
MikeE #1306310 Sun Apr 07 2019 04:25 PM
MikeE Offline OP
It showed 12.5 volts. I think that was the voltage going into the gun. I had the pickup on #1 plug, the dwell lead on the distributor side of the coil and the extra ground wire as directed by the company website. I will give it a try on a 12V vehicle.
1946 1-ton Panel
My Webshots Album
Re: Timing lights
MikeE #1306879 Fri Apr 12 2019 09:25 PM
MikeE Offline OP
Just to close the loop on this, I solved my problem with the innova timing light. I just sent it back. Amazingly easy with amazon. So the new search for a timing light and tach officially begins now!
1946 1-ton Panel
My Webshots Album
Re: Timing lights
MikeE #1306882 Fri Apr 12 2019 10:34 PM
General Purpose
I guess you know but.... if you got dwell, you then had to switch to timing, using a mode switch on the unit. You also needed to be in 4 cycle mode. You also can't have solid copper plug wire on no. 1. Don't look too long, most people just hook a 12V car, truck, lawn mower, battery charger..... to the light for the few times they check timing. Not a big deal and if a 6V light can't be used on 12V, that's no good.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: Timing lights
MikeE #1306897 Sat Apr 13 2019 01:20 AM
MikeE Offline OP
I went through all the modes and nothing. Not sure about the dwell either. I had it set for 6 cylinders and 4 stroke too
1946 1-ton Panel
My Webshots Album
Moderated by  48bigtrucks, MNSmith
