The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (hapydirty, carryall jerry, Forty9, 51sub, bandbrent, BC59), 313 guests, and 3 spiders.
Forums47
Topics116,102
Posts923,150
Members42,336
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 4 1 2 3 4
Widow maker rims #1306820 Fri Apr 12 2019 01:38 PM
can216 Offline OP
Looking to change a few tires. How crazy do I need to be to try this myself. 59 3800 Apache. Obviously I have never taken apart a split rim aka widow maker. Thanks
Re: Widow maker rims [Re: can216] #1306824 Fri Apr 12 2019 02:01 PM
Wrenchbender Ret. Offline
Show us a photo of the rims. All multi piece wheels are not "widow makers". You can do them yourself with the proper tools.
George
1956 Chevy 1/2-Ton Pickup
Re: Widow maker rims [Re: can216] #1306830 Fri Apr 12 2019 03:05 PM
Grigg Offline
Some info on the split rims and pictures from catalogs of the many types in this tech tip.
https://www.stovebolt.com/techtips/wheels/
1952 Chevrolet 3800 pickup
---All pictures---
Re: Widow maker rims [Re: can216] #1306845 Fri Apr 12 2019 04:44 PM
can216 Offline OP
Cool I will checkout the tech tip . I haven’t tried to put photos on this site yet but will get on it. Thanks
Re: Widow maker rims [Re: can216] #1306848 Fri Apr 12 2019 04:52 PM
can216 Offline OP
The rims are the 2 piece rim with the rounded front shoulder or collar and also a lock ring which looks to be a 1/2 “ wide sitting to the inside of the collar. I hope this helps. Thanks
Re: Widow maker rims [Re: can216] #1306851 Fri Apr 12 2019 05:32 PM
2ManyTrucks Offline
Hi can216,
You said two piece but then described a three piece rim,
Does it look like the attached photo ?
If it does that’s a firestone type AR three piece rim I think.
I’m pretty sure the widow maker is a two piece rim that locks in the center of the wheel.
I have a diagram of all the common types somewhere, if I find it I’ll post it here.
-s
1430s, 1420, 9430
-2MT
Re: Widow maker rims [Re: can216] #1306852 Fri Apr 12 2019 05:37 PM
2ManyTrucks Offline
Google image found something good enough
Attached, bottom right is the widow maker that gave all other multi piece rims a bad rap.
If I’m mistaken someone should chime in and correct me
-s
1430s, 1420, 9430
-2MT
Re: Widow maker rims [Re: can216] #1306858 Fri Apr 12 2019 06:49 PM
Grigg Offline
The above diagram is also in the further above linked tech tip.
Re: Widow maker rims [Re: can216] #1306898 Sat Apr 13 2019 01:22 AM
can216 Offline OP
Yes mine is like the type ar . Some what like it. 3 pieces yes. The large rim the smaller rim lip and the square rod . Now the second piece I describe the middle sized rim lip . This piece is not shaped as in the sketch. It is shaped like the bottom right of the type r. Like a round bulb. Also the photo I believe is the type ar. My rim is an 8 bolt with a center hole and 8 roughly 3” holes around the outer edge. I will try adding a photo
Re: Widow maker rims [Re: can216] #1306908 Sat Apr 13 2019 02:02 AM
can216 Offline OP
Ok found a photo in the gallery. Under 55-59 .medium to heavy trucks. Mike 69 cuda gramanns 1955 Chevy 2nd series two ton flatbed. This is the same rim style as I have. Thanks when my kids get home they will need to set me up for photos.
Page 1 of 4 1 2 3 4
Moderated by  Grigg
Powered by UBB.threads™ PHP Forum Software 7.7.3
