The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (37 GC, 55shaker, Dongray, Bob Kirk, delky, Cletus1950, 1 invisible), 169 guests, and 3 robots.
Forums60
Topics124,697
Posts1,006,493
Members45,007
Most Online1,229
Jan 21st, 2020
Image Posting Policy
New rear gas tank and fuel line
#1306655 Wed Apr 10 2019 09:51 PM
Currently the gas tank is in the cab. I am wanting to convert it to a rear gas tank. I will buy a new tank and new alum fuel line. The current line is 5/16" and the past owner ran a 1/4" line (dont ask) from the 5/16 line to the carb.
I have the original 283 V8 engine now. The sending unit on the new tank will be 3/8" and I was considering a 3/8" alum line to run from the tank to the front of the truck and replacing that small 1/4" line as well.
Do you folks see any issue by going up in the fuel line? My only other thought was to use new 5/16" from the tank to the front up to the carb, but did not know what the smaller line would impact the 3/8" sending unit.
JB
Re: New rear gas tank and fuel line
JFBerg713 #1312423 Thu May 30 2019 02:31 AM
I guess I would do what ever suit you. Its your truck. But since you asked, if the sender is 3/8, I would run it all the way to the carb. Aluminum line im not real fond of. The are a great heat conductor if routed close to exhaust mans etc and fuel dont like heat. Especially in Texas or any place for that matter where it tends to get abit toasty. I would use steel if possible. Rubber fuel specific hose is an option also and real easy to route.
JFBerg713 #1312745 Sat Jun 01 2019 12:13 PM
I moved my tank from the front to the back 59 Apache using a 16 gallon racing tank. Then I installed 3/8 braided wrap fuel line. Easy to install, looks nice! Plenty of fuel for the 383 Stroker!
Pops
Pops the truth is out there!
Moderated by  Hambone
