The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 registered members (Hotrod Lincoln, Fox, 49 Dually, 3B), 306 guests, and 3 spiders.
Forums47
Topics114,990
Posts912,328
Members42,071
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
1/2" flat faced lug nuts #1306498
Tue Apr 09 2019 11:40 AM
0
03marauderman  Offline OP
new york usa
Does anyone know of a source to obtain 1/2x20 flat faced lug nuts?.....Thanks
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1306507
Tue Apr 09 2019 12:27 PM
Harold46  Offline
Georgia
Harold
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1306539
Tue Apr 09 2019 06:13 PM
Eureka Jim  Offline
Pahoa, Hiwaii
Fastenal. Silicon Bronze finish #0178882: heavy hex #0158659.
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1306540
Tue Apr 09 2019 06:19 PM
0
new york usa
Didn't think to try Auto Zone....actually a few months back I went in there looking for a 'choke pull off' - they had no clue what I was talking about, and never heard of such a thing....I think looking for these lug nuts would fall in the same category........Now Fastenal....sounds like a sure bet....will check it out....Thanks !!!
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1306597
Wed Apr 10 2019 12:03 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
My COE had hub-centered wheel attachment - the wheels centered on the axle hubs.
The bolts had flat backs, no flange, and small slits in the top, like "Castellated" and "Marsden" nuts.
I do not remember if they had cotter pins (I think not).
Mine were relatively rare large Marsden nuts (image is attached, below). I found the part number, searched the Internet, and found 50 at $1 each (I needed 40).
Fastenal was going to be my next search.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1306639
Wed Apr 10 2019 07:51 PM
Grigg  Offline
Lexington, VA
Try these previous threads
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1213797/Searchpage/1/Main/177795/Words/%2BLug+%2Bnut+%2BMcMaster+%2B/Search/true/re-lug-nut-size.html#Post1213797
1952 Chevrolet 3800 pickup
---All pictures---
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1307000
Sun Apr 14 2019 12:51 AM
0
new york usa
Bartamos....My truck is a 1970 C30 mason dump....See my post titled '70 C30 wheel conversion' Fastenal was the solution that had a 1/2x20 nut with a flange 10 per bag @ $7.59....Isn't that sweet.... My luck on line, as with e-bay didn't turn anything up.... If you view my post on the wheel conversion Grigg was helping me, much appreciated.... but at the end of the day, I ended up using the original type wheel.....I wanted to avoid the rim with the outer ring & tube, but to no avail....I used two of my original wheels & located 2 more....Right now they are out being sandblasted & powder coated (after I straightened with the torch the sledge hammer blows on the edges) ....all set up by a truck tire shop where I will purchase the tires...I opted for radials 215/85/16, rather than the bias 750/16 which I would have preferred but they had no source other than Coker. Seeing they were so good about breaking down 7 wheels to find two good ones I felt obligated to by the tires they had in stock...Goodyear/Firestone.....Can't bring myself to buy & look at the Chinese brand.....despite the savings.....I'm still amazed on how stupid people can be....The guy I got the truck from had the original rear inner wheel with the late model wheels on the outer, neither hub or lug centric just a couple of large flat washers with standard coned lug nuts installed backwards....
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1312320
Wed May 29 2019 02:10 PM
glenns towing  Offline
Pittsburgh Pennsylvania
I actually read through this forum a while back and said to myself, "ha, I never seen them b4." Low and behold I bought a gmc 2500 chassis a few days ago now and just noticed last nite it has the same lugnuts. Go figure. lol. Do you happen to know what torque they are supposed to be at?
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1312845
Sat Jun 01 2019 11:55 PM
Hotrod Lincoln  Online
Boltergeist
Dellrose, TN
I've been known to use 1/2-20 tapered lug nuts on a 1959 3800 I had- - - -turned backwards. They look a little strange, but they hold the wheels on just fine!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 1/2" flat faced lug nuts [Re: 03marauderman] #1312942
Mon Jun 03 2019 01:10 AM
I just took the wheels off my roller and put it on jack stands. Same lug nuts. They weren't tight at all. My wifes car lugnuts were tighter yesterday when i had a tire to repair. Anyone know what the actual torque spec is supposed to be for these? My roller is a 63 GMC 2500.
Page 1 of 2 1 2
Moderated by  Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
