The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (klhansen, DaveMcK38, Hotrod Lincoln, Justhorsenround, ClassicsR4Me, jim h, 1 invisible), 373 guests, and 7 spiders.
Forums48
Topics117,483
Posts939,165
Members42,871
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Solder or just crimp? #1306396 Mon Apr 08 2019 03:00 PM
Matt_Texas Offline OP
I got an EZ wire 21 mini. For my 1950 3100.
I want to do this right but I'm getting a lot of back and forth on whether to solder or not. Each argument sounds convincing too. Are factory wires soldered on new stuff?
I plan to start wiring with next pay check.
Re: Solder or just crimp? [Re: Matt_Texas] #1306399 Mon Apr 08 2019 03:06 PM
Hotrod Lincoln Online
Boltergeist
Factories don't necessarily do things "right"- - - -they choose to use the methods that will get a vehicle through its warranty period with a minimum of free repair work. If you're interested in your wiring lasting more than 8-10 years without problems, solder the connections. Crimped connections are "good"- - - -properly soldered ones are "better". A poor soldered connection isn't as good as a crimp done right.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Solder or just crimp? [Re: Matt_Texas] #1306401 Mon Apr 08 2019 03:15 PM
Forty9 Offline
Better to solder now than wish you had after installing. I soldered as many connections as I could when I first got my 49 3100 in 1987 and while it was a PITA since wiring was already installed I haven't regretted all the crawling around to get it done. Done right you never have to worry about it again!
Ed
Re: Solder or just crimp? [Re: Matt_Texas] #1306419 Mon Apr 08 2019 06:07 PM
I hadn't thought of them making the vehicle last just long enough for the warranty...
Solder needs to be resin 60/40?
Are some solder guns better than others?
Re: Solder or just crimp? [Re: Matt_Texas] #1306420 Mon Apr 08 2019 06:07 PM
Fox Offline
I did both and heat shrink wrapped all of them. Takes a long time but peace of mind.
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: Solder or just crimp? [Re: Matt_Texas] #1306432 Mon Apr 08 2019 07:59 PM
bartamos Offline
Truck Whisperer
You will find out that soldering is not all that easy. Orienting the wire while holding the terminal end in some clamp or other. You need two hands to solder. Then you will melt the insulation. The heating of the insulation and the solder on the joint, will cause the termination to be overly stiff and not flexible. Then getting solder on a place that won't allow terminal to be installed in a connector shell. Screwing up the connector shell trying to get it in there. You may have "cold" solder joints you won't see. Not to mention it will take you forever to finish.
A good crimp contact using a good crimp tool is plenty good for automotive. Solder is not necessary. The crimps will not come loose.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Re: Solder or just crimp? [Re: Matt_Texas] #1306436 Mon Apr 08 2019 08:31 PM
beltfed Offline
By now it should be obvious that both crimped and soldered connections have good and bad points. I have been soldering since I was 18 and in the army. Personally I don’t use a solder gun but a pencil type. Guns used improperly create too much heat which is bad. As far as crimping always use the type that has a ‘tooth’ to bite into the connector. Always put the tooth opposite the connector seam. The best connection for wire has two components, electo-mechanical. When possible I crimp a connector like the “Staycons” we see so often. Then I tin and heat with the pencil in a selected area and watch the solder ‘flow’ into the barrel of the connector. I would think you could learn some tricks from Utube.
Re: Solder or just crimp? [Re: Matt_Texas] #1306437 Mon Apr 08 2019 08:47 PM
bartamos Offline
Truck Whisperer
Of course, this issue is a very old issue that never gets resolved.
We always allow the person to do what they wish after all the opinions are in. smile
Re: Solder or just crimp? [Re: Matt_Texas] #1306443 Mon Apr 08 2019 09:31 PM
Boltergeist
I use the highest-wattage pistol grip solder gun I can find, use very small-diameter solder, and don't spend enough time on any particular connection to experience any of the heat-migrating problems our resident curmudgeon describes. Getting the connection HOT quickly and getting a good solder flow only at the terminal is the trick to making good low resistance connections without melting everything else in the neighborhood. I consider a 350-400 watt gun to be an abso9lute minimum, and I've got the tip up to full heat before touching it to the connector.
Re: Solder or just crimp? [Re: Matt_Texas] #1306444 Mon Apr 08 2019 09:40 PM
bartamos Offline
Truck Whisperer
If you mean me, Yes pot, I am black.
Page 1 of 3 1 2 3
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
