The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (EdPruss, Hotrod Lincoln, DennisM, Dr. Jag, 5 Window 9434, 1 invisible), 269 guests, and 3 spiders.
Forums47
Topics114,621
Posts909,404
Members41,973
Most Online940
Apr 5th, 2017
Image Posting Policy
348/409 Distributor and coil mounting bracket #1305440
Sun Mar 31 2019 04:50 PM
Spartan  Offline OP
ID
Distributor was working and the. There was an electrical short somewhere and it started smoking a little. It smells like burned electronics it might still work but I dropped an HEI in so I never texted it. But everything else is great. The shaft and gears are all in great shape. The coil bracket sits next to the distributor and bolts the the intake manifold I think. Coil is vertical right next to the distributor on the driver side. I'll get pictures up later today.
Hoka Hey!
Spartan
1959 Chevy Spartan 100 "Battle Wagon"
2008 Buell Lightning "War Horse"
Re: 348/409 Distributor and coil mounting bracket [Re: Spartan] #1305945
Thu Apr 04 2019 03:43 PM
drdoug  Offline
Prosper, TX
Hey, Spartan... does the distributor still have it's aluminum number tag on it, and if so, the number? The number should be something like 1111023. Here's a couple example photos (SBC dist's) to show what I'm talking about regarding the number tag. Can you post a few photos of the distributor, including with the cap off? Thanks!
Re: 348/409 Distributor and coil mounting bracket [Re: Spartan] #1306016
Fri Apr 05 2019 02:44 AM
Spartan  Offline OP
ID
DELCO REMY
1111023
4 J 21
Dont know if that makes sense but thats what my sister was able to get off of it.
Hoka Hey!
Spartan
Re: 348/409 Distributor and coil mounting bracket [Re: Spartan] #1306050
Fri Apr 05 2019 01:15 PM
drdoug  Offline
Prosper, TX
Makes perfect sense... PM'ed.
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
