New Forum Added in Parking Lot
EARLY BOLTS
1916 - 1936
1928 Chevrolet AB Canopy Express "Justin"
Discussing issues specific to the pre-1937 trucks.
Forums64
Topics122,558
Posts989,211
Members46,963
Most Online1,229 Jan 21st, 2020
#130589
Thu Dec 13 2001 05:35 AM
I was always going to take an old head and put it in the chop saw and cut it in half through the intake port, just to see if the water jacket is close. If not, why couldn't you drill holes in the head UNDER the valve cover for the injectors? If you drilled them at an angle, you could have the injector shoot right down on the valve. Some sort of fuel rail could be make to supply the injectors. Imagine the dumfounded looks when you popped the hood and the only thing on the intake manifold was a throttle butterfly and a MAF sensor  I just got back from a technical school on John Deere High Pressure Common Rail fuel systems. This system is absolutely AMAZING, both in diagnostic abilities and horsepower output. This will require a lot of thought to adapt this technology to a Stovebolt, but I think it could be done.
#130590
Thu Dec 13 2001 12:03 PM
Racecarl,,,,,you have my ears perked!!!! This sounds interesting!
#130591
Thu Dec 13 2001 02:34 PM
Anonymous
Unregistered
OK Racecarl . . . get you camera and chop saw warmed up and lets start a new thread!
#130594
Sun Dec 16 2001 05:42 AM
Anonymous
Unregistered
Uhhhhh . . . Vaughn, I think there is something funky about the Motorhood link. Other than that one, these are among the best I have seen.
#130595
Sun Dec 16 2001 01:40 PM
Peggy took care of it, Ken -- Thanks for the vigilance. It was fun cruising to the Turbo Buick site -- When those Grand Nationals came out, I wanted one so bad. A buddy of mine bought one and took me cruising the night he got it. Then he parked in downtown in DC and it was gone. He got it back a month later -- well, just the frame and the body... Had less than a 1,000 miles on it, too.
The collective group of dedicated volunteers behind Stovebolt.com
#130596
Sun Dec 16 2001 07:36 PM
Take a look at the picture Tony posted.
In the center of the intake port is part of the head casting that the head bolt goes through. It is basically round, it does not separate the two intake valves behind it. A trick to improve intake flow a great deal, is to mill the casting out of the port. A stud is used instead of the original bolt, with the stud protruding into the port only by enough to install a nut. The flow over the nut does not disturb intake flow nearly as much as the casting did. The hole left above the port where the bolt went through is closed off using a plug.
This should improve the power of an injected engine as well.
#130597
Fri Dec 21 2001 02:45 PM
Tony, I may try to get pics of, here we have 250 with multiport efi. But with a whole different head. Separeted runners on all cilinders, they do not merge after the bolt. Greybeard, this procedure helps in high rpm, hurts a lot the low end grunt. And we can have for sure that to keep it going must run a li'l rich in lower rpms, so fuel consuption suffers a lot. For a long time the tunners here used to do it, remove the center of the port, but it's results are not clear, some like, some dislike, but listening to the results of a 12 port wayne on a stovebolt, I'd say that I'd rather have a full divider in a head port than running an engine with a common runner for 2 cilinders. Just my 0.02.
Alexandre Garcia
#130598
Tue Jan 01 2002 02:07 AM
Wow! you guys are too technical for me!  Back until 99 models in truck plant here, we made Mexican sixes and trucks that were mostly the same as the old 250's. They had a fuel injection body in place of carb on them the last few years. don't know if you can go to Chevy dealer and get #'s of parts or not. Maybe the last poster is talking about this engine as it was made in Brazil I believe. It's just a stock set-up, not racer, but may be better than a carbed one.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
