The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 members (87GN, D B Cooper, John L., RdsLessTaken, Jim K, olezippi), 176 guests, and 3 robots.
Forums50
Topics121,336
Posts977,390
Members44,205
Most Online1,229
Jan 21st, 2020
Image Posting Policy
check valve and proportioning valve
#1305631 Tue Apr 02 2019 12:44 AM
8
87GN Online OP
nothing beats a try but a failure
So, I am at the point on my rebuild were I am installing the plumbing. I did not replace the original single bowl master cylinder with another. A double bowl MC is installed. Should there be a check valve and a proportioning valve?
1955.1 3600 5 window 4 speed all original.
Re: check valve and proportioning valve
87GN #1305637 Tue Apr 02 2019 01:25 AM
3B Offline
Hy 87GN, I am going to assume that you are working on a 1955.1 3600, by your pictures and your signature line, please remember to give us that information when you ask questions. What was the master cylinder you installed originally intended for? Are you going to have drum brakes all around or will you be doing a disk brake conversion?
87GN #1305645 Tue Apr 02 2019 02:09 AM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
If you are doing drums all the way around no extra valves are required. 🛠
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2)
‘39 Dodge Businessmans Coupe
USAF 1965-69 Weather Observation Tech (got paid to look at the clouds)
"I fought the law and the law won" now I are a retired one!
Justhorsenround #1305676 Tue Apr 02 2019 08:29 AM
I agree, but may I add a couple of possible exceptions he might want to be aware of?
If the master cylinder is lower than the wheel cylinders you would need an inline check valve to prevent backflow. I also think there would be a little quicker brake response with 10-lb inline residual pressure valves front and rear to offset drum brake spring tension.
1949 Chevy Panel Truck
87GN #1305682 Tue Apr 02 2019 11:40 AM
8
87GN Online OP
Yes, all 4 of the drum brakes will be reinstalled completely new. The dual bowl MC is mounted in the original location except for the mounting bracket that came in the kit. The wheel cylinders are below the MC as it sits on level ground but they would not be below the MC on a hill. The double bowl MC intention was to provide a second chance to stop if a failure accrued in one of the lines. I know it's not original and I had to make that hard decision to make this alteration to the master cylinder.
87GN #1305688 Tue Apr 02 2019 12:42 PM
The original master cylinder and some replacements already have residual pressure valves built in.
Find out what you have before adding other things.
A check valve is a bad idea, unless you want your brakes engaged always.
The residual pressure valves are a type of check valve but only hold the listed pressure, freely return excess pressure. The brake shoe return springs should be able to provide more pressure than the valve is rated for.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
87GN #1305759 Wed Apr 03 2019 12:14 AM
I went to a double mc and stayed with drums and had to add 10lbs residual check valves. I added one to the front line and one to the rearclose to the mc. I was told to add 2 on the front line after the split and then add a proportion valve but I didn’t go that route. They work great now, before the check valves I couldn’t get any pressure from the pedal. Now it’s good and firm.
Moderated by  SWEET
