The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (Hotrod Lincoln, LeeD, 3B, Joe H, lastchancetowing, D B Cooper), 316 guests, and 3 spiders.
Forums47
Topics116,112
Posts923,265
Members42,338
Most Online940
Apr 5th, 2017
Image Posting Policy
Radio Push buttons #1305215 Fri Mar 29 2019 11:12 PM
BobF Offline OP
Looking to replace the push buttons on my 1950 Chevy 3100 radio but having trouble removing old ones, any tips on getting them off? Thanks.
Re: Radio Push buttons [Re: BobF] #1305229 Sat Mar 30 2019 12:39 AM
truckernix Offline
I used to use a large set of cutters or pliers and break bits off. Now I use a heat gun. I heat the plastic up until it get gummy and then remove it with pliers. I pull each one out in the setting position, one at a time while I remove them. I soak the new button in hot water before installing them.
1951 1 Ton Completed
Re: Radio Push buttons [Re: BobF] #1305545 Mon Apr 01 2019 01:23 PM
BobF Offline OP
Thanks truckernix followed your suggestions and they worked perfectly, old knobs off new ones on. Appreciate you taking the time to respond.
Moderated by  truckernix
Powered by UBB.threads™ PHP Forum Software 7.7.3
