The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (Bill Trotter, Grigg, 4100 Fire Truck, Green_98, bwilliam79, 1 invisible), 286 guests, and 3 spiders.
Forums47
Topics115,007
Posts912,469
Members42,075
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306023
Fri Apr 05 2019 03:22 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Any bleeder without a separate chamber for air and fluid with a rubber diaphragm in between is risky business.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306068
Fri Apr 05 2019 03:07 PM
MNSmith  Offline
So Cal
Makes a good possibility for injecting air in to the system. That's why the pro systems are a bladder tank.
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306073
Fri Apr 05 2019 03:45 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
Does the $99 at HrL’s eBay link above have a bladder?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306108
Fri Apr 05 2019 07:44 PM
MNSmith  Offline
So Cal
It sure looks like it.
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306117
Fri Apr 05 2019 08:52 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
The search results changed.
When I posted, the Motive Pressure Bleeder was the first one displayed. Mine does not have a bladder.
This one is now the first displayed - does it have a bladder?
It would be more helpful if a product name and number is posted (or, an eBay listing number).
Tim
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306138
Fri Apr 05 2019 11:55 PM
4100 Fire Truck  Online
Cedar Falls, Iowa
I have had great luck with every dry brake system for many years all by myself, with a simple to use OTC air-powered vacuum bleeder. It's all about getting fluid to move quickly through the lines is all.
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306173
Sat Apr 06 2019 02:52 AM
Boltergeist
Dellrose, TN
Posting Ebay links gets the thread edited pretty quickly. Sort of puts us between a rock and a hard place, doesn't it? That's OK- - - -the PC Patrol will figure it all out!
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306208
Sat Apr 06 2019 04:13 PM
MNSmith  Offline
So Cal
I don't mind an eBay link when used as an example. Especially when you're not trying to sell something here. Better would be to post a picture of the item, but not all folks are savvy enough for that. This is the pressure bleeder that is being discussed in this topic. It is a rubber bladder style. Brake fluid is in one side of the chamber and air pressure is applied to the opposite chamber. These items can be found for a reasonable cost on eBay. But, as with any tool, you need to ask yourself if it is worth the cost for a one time or more usage, or will it be used more often to make it worth it. Also keep in mind, rubber bladders won't last forever. I have yet to see one of my pressure brake bleeder bladders go bad. I can't say that for my BG trans flush machine. I believe we are on our 3rd bladder. And the machine is much younger than our brake pressure bleeder. I'ts all about the chemicals!
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306209
Sat Apr 06 2019 04:46 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
If we cannot post a link to an eBay listing, please post the company/product name and part number.
Then, we know what product is being referred to.
It would also be OK to say that you saw it for sale (at a good price) on eBay.
Tim
Re: Making a brake pressure bleeder? [Re: Paul_WNC] #1306215
Sat Apr 06 2019 05:22 PM
Justhorsenround  Offline
Grease Monkey
El Reno, Okla
Here is why we don’t post EBay links in the regular forums. They expire! So 2-3 months from now when a member is doing a search the thread comes up with an expired EBay link. The best way is to just type in the EBay item # in your post and the interested members can do an EBay search for that number.
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Page 2 of 2 1 2
Moderated by  48bigtrucks, MNSmith
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
