The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 members (42465967, Johnny N, Jon G, Goach2, 3 invisible), 179 guests, and 3 robots.
Forums50
Topics118,897
Posts951,664
Members43,287
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Hydraulic clutch pedal
Yukon56 #1305403 Sun Mar 31 2019 06:16 AM
I used an early '60s Chevy dual master cylinder (brake-clutch) on a '34 Ford pickup, along with the matching clutch slave cylinder. Unbelievably simple to set up - run the hard line anywhere you need to without hassling with routing mechanical linkage. Since then I'm sold on hydraulic clutch systems.
1951 Chevy Panel Truck
Yukon56 #1312348 Wed May 29 2019 06:50 PM
I know this thread was a couple of months back but just wanted to share some wisdom. I 'm putting a Muncie in my 59' and shopped around for a hydraulic clutch kit, plenty out there but most were out of budget (CHEAP). I found an assembly at Speedway that was completely bolt in (you may need to fab up a support bracket) they even had a master cylinder that matched the bore needed. All told I have about $200.00 in parts excluding the clutch disc and pressure plate. Still working out the under cab mount for the master cylinder as I wanted to keep the original pedal assembly. I'll post some pics when its completed.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
miraclepieco #1314301 Fri Jun 14 2019 02:23 PM
Curious, did you use the bell housing with the passenger side access?
Page 2 of 2 1 2
Moderated by  KCMongo
