The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Time to gathering together!
Fall Happenings
That time of year with some last chances to get together in bunches. Time to check out:
THE SIDE LOT
From Coast to Coast and some International gatherings listed, too.
Next up: the ODSS gathers this week (Sept 22-24) at a yearly ATHS show in Winchester VA.
Since we put up this promo last week, a bunch of new postings of Swap Meets, Cruisin's, and more
in the SIDE LOT.
See what's happening with a Stovebolt Collective near you
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (32vsnake, baldeagle, Peggy M, oldbolter, Lightholder's Dad), 103 guests, and 3 robots.
Forums60
Topics129,095
Posts1,046,668
Members46,190
Most Online1,229
Jan 21st, 2020
#1304748 Tue Mar 26 2019 07:12 PM
panic Offline OP
I've been asked "I have the valve opening & closing points of a cam, but how do I calculate the intake and exhaust centerlines, and the LSA or lobe center angle?"
Using the McGurk #18 data:
For the intake lobe: (intake closing - intake opening) / 2, then add 90 degrees
Example for 10-55 timing: 55 - 10 = 45, divide by 2 = 22.5, add 90 = 112.5 degrees ATDC
For the exhaust lobe: (exhaust opening - exhaust closing) / 2, then add 90 degrees
Example for 72-32 timing: 72 - 32 = 40, divide by 2 = 20, add 90 = 110 degrees BTDC
LSA: (intake CL + exhaust CL) / 2
112.5 + 110 = 222.5 / 2 = 111.25 degrees
I just wrote an Excel spreadsheet that calculates this automatically from your input, e-mail me for a free copy: jdiamond (at) optonline.net
panic #1304857 Wed Mar 27 2019 01:55 PM
Good school Panic, only thing missing is how to determine cam advance ground into the cam.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
panic #1304861 Wed Mar 27 2019 02:08 PM
Use this site, https://www.blocklayer.com/degree-wheeleng.aspx to build your custom degree wheel. Just add the data from the cam card, and you have a degree wheel just for that cam!
panic #1304871 Wed Mar 27 2019 03:22 PM
Thanks, Joe! Added to my "favorites" list!
BTW- - - -has anybody else thought about drilling and tapping the snout of a stovebolt cam and using a harmonic balancer installer to push the timing gear on?
"Freedom's just another word for nothing left to lose"
Kris Kristofferson
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
WAG MORE- - - - - -BARK LESS!
panic #1304889 Wed Mar 27 2019 05:10 PM
panic Offline OP
Typically the suggested (or already selected) intake lobe center is 4 degrees advanced from the CL.
More advance closes up the intake valve-to-piston clearance, more retard closes up the exhaust-valve-to-piston clearance.
Overlap and LSA are constants (at least, in single cam engines!).
Moderated by  Justhorsenround, KCMongo
