The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
3 registered members (stoveboltgator, klhansen, TPR57C), 273 guests, and 3 spiders.
Forums47
Topics115,005
Posts912,449
Members42,075
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 3 1 2 3
Re: Blue Flame or Not [Re: Craig /49 Panel] #1304539
Mon Mar 25 2019 02:40 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Call them- - - -they'll ship direct to you. I'm pretty sure they'll also have the right lifters. The last one I bought was around $100.00. Any set of stovebolt solid lifters will work with that cam. The older style "milk can" lifters require shorter pushrods than the ones from the late 1950's and newer.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Blue Flame or Not [Re: Hotrod Lincoln] #1304940
Thu Mar 28 2019 12:03 AM
Craig /49 Panel  Offline OP
Lake Placid
Thanks Jerry, I do just that! thumbs_up
Still trying to get ole Betsy back on the road.
Re: Blue Flame or Not [Re: Craig /49 Panel] #1305016
Thu Mar 28 2019 02:31 PM
WE b OLD  Offline
marion, in. usa
A side note. When young people ask me what engine I have in my 54 iI tell them a Corvette. The first response is boy that must be fast. Then I open the hood and explain. BTW it is fast enough to keep up.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery
2015 GMC terrain.
Pix on Photobucket
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307533
Thu Apr 18 2019 05:45 AM
ApacheFiend  Offline
Dallas, TX
Craig,
I bought on of those Cams from Elgin and had to order it through an engine building in my area. Call Elgin and they will let you know who the closest seller is to you.
58' 3200 235 3-speed/OD
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307572
Thu Apr 18 2019 02:21 PM
EchoBravoSierra  Offline
Spring, TX
I contacted Elgin about some rocker arms a couple months ago, and was told the same thing- that I must order them from one of their distributors, that they don't sell directly to the public.
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307579
Thu Apr 18 2019 03:48 PM
Boltergeist
Dellrose, TN
I've been doing business with the "Internal Engine Parts" warehouse in Nashville Tennessee for several years, and they distribute Elgin products. It looks like IEP is basically a southeastern USA company, but they definitely have a business relationship with Elgin. IEP also beats most of the online parts stores price-wise because they mostly cater to professional shops.
http://www.enginepartscenter.com/corporate.html
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307638
Thu Apr 18 2019 11:57 PM
Lake Placid
Ok Guys I really appreciate all the Elgin information. I didn't buy the cam yet. I've hit a snag in my rebuild activity - a little issue with my heart. I was re-reading all the posts considering what I was going to do and I see that Jerry mentioned that the block should be cross drilled for lifters. Does that mean that I could use a hydraulic cam instead of a solid one. I haven't had a great deal of luck getting the valves adjusted in my truck (can't seem to get rid of a mis) and the thought of changing over to hydraulic sounds appealing. Since I'm on a health hold I'm in no hurry to tackle the rebuild anyway. If I can use a hydraulic cam what would be a good performance one and is there a difference in the push rods for the lifters.
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307640
Fri Apr 19 2019 12:18 AM
Lake Placid
Looking back I see drdoug said I could use a hydraulic one. Any recommendations?
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307652
Fri Apr 19 2019 01:50 AM
drdoug  Offline
Prosper, TX
Melling has two - their PN CCS-6 - which is a very mild, OE grind, or the slightly hotter CCS-5 which is the same advertised duration, but a bit more lift. Sealed Power (PN HT761) has hydraulic lifters, but others have reported issues with recent-build lifters, and I can't vouch for these specifically, other than to say I've had good luck with Sealed Power products over the years. I'm sure there are others...
Re: Blue Flame or Not [Re: Craig /49 Panel] #1307656
Fri Apr 19 2019 02:09 AM
Boltergeist
Dellrose, TN
RUN- - - - -do not walk away from a stovebolt with a hydraulic cam. They were temperamental with original equipment GM lifters 50-something years ago, and the current crop of overseas-made aftermarket lifters suck like a Dyson vacuum cleaner! Adjusting mechanical lifters is ridiculously easy if you get the engine up to full temperature first and do the adjustment with the engine stopped. Chasing a moving rocker arm around with a feeler gauge, a screwdriver, and a wrench takes three hands and a Cajun voodoo priestess from a "Swamp People" bayou chanting spells in some archaic language while you do it!
Page 2 of 3 1 2 3
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
