The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (Ga92009, AlanV, DavidBraley, DennisM, Bogart's Truck, 1 invisible), 287 guests, and 3 robots.
Forums50
Topics121,476
Posts973,882
Members43,939
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Matt M's: Canadian '49 3600
#1303308 Sat Mar 16 2019 04:15 PM
49ratty Offline OP
Well, we've already progressed faster and farther than expected, so I better start this now or I'll never remember it all!
The truck: 1949 Chev 1420. (Canadian 3600) 3/4 Ton. Appears all original, unmolested. Was clearly a farm truck.
The buy: Purchased from a local in Kitchener, Ontario, Canada. Truck came in from Manitoba, Ontario
The Plan: Fix up with a working man's budget just enough so it's legal and rolling. Then Drive it and see what it needs, and plan future modifications from there.
The truck was purchased by myself and my Father, with the intent to be a father/son project. I also have 2 kids, a Son (8) and daughter (2) who I hope to be involved. That said, the most important 'plan' for this truck is to build memories, regardless of what ends up of the truck!
Our Beginning:
Truck was delivered to our house (just south of Woodstock, Ontario) January 2nd, 2019. Almost the dead of winter, to be sure, not much work was going to happen outdoors this time of year. Despite that, my son and I went out to tinker all the same. The motor was seized up, so we pulled spark plugs and started with Diesel oil, a little at a time and let it creep in. We also put some ATF, and some WD40 (he loved spraying this in!). After about a week on/off of spraying the top end and in the cylinders, on the COLDEST day of the year (silly me), I decided to reorganize the shop and pull it inside.
Warm inside, snow melted, we were able to really get a good look at the truck. As you guys know, and I as I soon learned, there's not really any great way to turn these motors over. I tried making a hand crank tool, but the motor was too tight, it bent the tool!
I jacked it up in the air and pulled the flywheel cover off. With a brass drift against the flywheel I tapped it back and forth until I got movement. Drained the old junk out of the crankcase and then filled with some used oil for testing.
When my son got home from school I said let's take the gloves off, and let him hop inside and try the starter! To our surprise, not only did it turn over, IT STARTED!
It was knocking/ticking pretty good, a quick look under hood (valve cover was off) and could see that #2 exhaust valve and rocker was not moving, so we shut it down, but great success, never the less we were excited. The look on his face was priceless! yahoo
Next off came the pushrod cover. Bent rods on #2 Whoot! nanner Haha. Ordered parts, swapped out, cleaned up a whole lot of stuff, pulled rockers and freed up the valves.
Put it back together enough to run it and tried again. Not only did it run, it ran really good all things considered!
Now for some pictures! I'll reserve a few posts under this one as well to continue the story and get up to date when I get a shot to get back. Kid's are calling now!
'49 3/4 Ton
"It's hard to make a comeback when you haven't been anywhere"
Re: Matt M's: Canadian '49 3600
49ratty #1303309 Sat Mar 16 2019 04:20 PM
49ratty Offline OP
Now to do what I should have done before ever running it (hindsight is 20/20, I was excited and running without enough caution), I pulled the pan down and had a look. EEK! sludgy mess, indeed.
Lot's of cleaning later, I was ready for reassembly.
I stole the wife's Strainer to make a new mesh screen for the pickup tube, since I couldn't find one anywhere quick.
Reserved space #1**********
'49 3/4 Ton
49ratty #1303310 Sat Mar 16 2019 04:21 PM
49ratty Offline OP
Reserved space #3**********************
'49 3/4 Ton
49ratty #1303311 Sat Mar 16 2019 04:21 PM
49ratty Offline OP
Reserved space #4*****************
'49 3/4 Ton
49ratty #1303312 Sat Mar 16 2019 04:21 PM
49ratty Offline OP
Reserved space #5********************
'49 3/4 Ton
49ratty #1303383 Sun Mar 17 2019 03:15 AM
Looks like you've been busy!! And you've got some good helpers too!
Rich
'47 Loadmaster [stovebolt.com]
Time flies like an arrow.
Fruit flies like a banana.
49ratty #1303594 Mon Mar 18 2019 06:03 PM
Workshop Owner
Hello 49ratty,
Your truck looks to be in pretty good shape body wise. I think it's great that you're making it a family project.
Thanks for sharing the pics. I'm looking forward to following your progress.
J Lucas
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
1959 Chevy Apache 31 Fleetside
1959 Chevy Apache 32 Fleetside
1959 Chevy Viking 40
My Flicker Photos! [flickr.com]
Moderated by  J Lucas
