The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (Gazz, carryall jerry, Hotrod Lincoln, dougs, Barnfind49, 55 SHAKER), 323 guests, and 2 spiders.
Forums47
Topics116,096
Posts923,071
Members42,329
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: Brake Bleeder Help [Re: tom moore] #1303051 Thu Mar 14 2019 08:12 PM
klhansen Offline
The bottle would need to be upside down, right? When the level gets below the tube, it would burp some air into the bottle and let a little brake fluid out.
Pretty ingenious idea.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: Brake Bleeder Help [Re: tom moore] #1303053 Thu Mar 14 2019 08:38 PM
drdoug Offline
I like the "intravenous bottle" approach, 4100 FT! That should help a lot with ease of use, and vacuum bleeders do work well.
One of the reasons I like the pressure bleeders is that they take care of the auto-fill needs with the way they work, too - reservoir is built in - but they do require a sealed adapter cap at the M/C.
The nice thing in either case is that they offer one-person operation, and no worries about the M/C piston moving out of it's normal stroke range, risking damage to the internal seals.
Cheers.
Re: Brake Bleeder Help [Re: tom moore] #1303125 Fri Mar 15 2019 05:48 AM
Dusty Offline
I like the upside down bottle idea , but that would still need two people .
I don't have the help so just pressurized the master cyl. Gotta keep checking the level , after each wheel , but I can manage that .
Re: Brake Bleeder Help [Re: tom moore] #1303148 Fri Mar 15 2019 02:57 PM
tom moore Offline OP
Thanks. Good picture too. Probably can use that original mc cylinder cap and then remove the air fitting, and thread a screw plug into that hole.
Re: Brake Bleeder Help [Re: tom moore] #1303240 Sat Mar 16 2019 02:53 AM
Harold41 Offline
I used what I had available in scrap parts at the time I needed it, a little crude but it worked.
A piece of aluminum plate slightly larger than the master cylinder. Tapped a fitting into the center of the aluminum plate for my home built vacuum/pressure bleeder. Two holes at the edge of the aluminum plate outboard of the master cylinder with two bolts through the holes down to a piece of flat bar under the master cylinder. Cut a gasket from some scrap rubber and tightened the bolts. Removed the tubing from the fitting after bleeding and the spillage of fluid when removing the plate was minimal. I did a complete rebuild so I pulled a slight vacuum before adding the fluid and the bleeding required was minimal.
Harold Wilson
41 Chevy 3/4 Ton
Page 2 of 2 1 2
Moderated by  48bigtrucks, MNSmith
Powered by UBB.threads™ PHP Forum Software 7.7.3
