The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (HandyAndy, Apache1, Brad Allen, D B Cooper, 2 invisible), 236 guests, and 3 spiders.
Forums47
Topics114,593
Posts909,210
Members41,963
Most Online940
Apr 5th, 2017
Image Posting Policy
1949 GMC Interior Trim Code #1302261
Fri Mar 08 2019 10:30 PM
Hogieab  Offline OP
AB, Canada
Fellas, I have a 1949 (Canadian) GMC 3/4 ton Pickup Delivery. The tag states that the Trim code is 394......I am having trouble finding out what color the interior was.....body is Ferrara Blue if that helps at all.
Help?
Hogie
Re: 1949 GMC Interior Trim Code [Re: Hogieab] #1302266
Fri Mar 08 2019 11:54 PM
2ManyTrucks  Offline
california
hi Hogieab
Trim code is 394 = Brown Leatherette
i don't have a comprehensive list of trim codes, however that particular one was very common and is also the trim code for a few of my Canadian trucks.
This trim should have brown piping on the seat with two seams also piped running down at a curved line on the front edge of the bottom seat.
the door panels and ceiling are matched to the seat but use a laminated embossed material onto stiff cardboard so it's not exactly the seat material but looks like it is from a few feet away.
the back of the seat top will have a stiff black cardboard that hooks on at three locations
i have samples of all these original parts and materials for this trim code.
you won't find a reproduction interior parts that are correct
this interior is likely a bit different than all USA models as the Canadian built trucks sourced Canadian materials.
all repo parts are modeled after USA versions which must have been different, or are just lacking in correct detail.
-s
1430s, 1420, 9430
-2MT
Re: 1949 GMC Interior Trim Code [Re: Hogieab] #1303193
Fri Mar 15 2019 09:36 PM
Hogieab  Offline OP
AB, Canada
2ManyTrucks. Thanks for the great info. You wouldn't happen to have an image of the Brown Leatherette seat would you? I'm not looking to be exact with the interior, but would like to match the colour as much as possible.
Thanks again for your help
Hogie
Re: 1949 GMC Interior Trim Code [Re: Hogieab] #1303194
Fri Mar 15 2019 10:26 PM
2ManyTrucks  Offline
california
hi Hogie,
sorry i checked my photos and i don't have any good ones of the original material samples that i saved
i'll be able to take photos in a few months when i'm back near my trucks
i have some photos of the seat before i took it apart, but the exposed material is very damaged, the good samples were on the back edge out of the sun and weather.
ping me again in the summer time
-s
1430s, 1420, 9430
-2MT
Re: 1949 GMC Interior Trim Code [Re: 2ManyTrucks] #1303750
Tue Mar 19 2019 04:10 PM
Hogieab  Offline OP
AB, Canada
Great. Thanks again for your help
Moderated by  Rusty46
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
