The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 registered members (KEVINSKI, Hambone, ESum, DaveV, 52_Ton, 1 invisible), 262 guests, and 3 spiders.
Forums48
Topics117,049
Posts935,142
Members42,762
Most Online1,027
Dec 27th, 2019
Image Posting Policy
Page 1 of 2 1 2
Hydraulic clutch pedal #1302863 Wed Mar 13 2019 03:38 AM
Y
Yukon56 Offline OP
Hello,
I am going to be putting in a hydraulic clutch setup to in my 1956 chevy 3100. I'm sure someone here has solved this setup..any suggestions? I see Wilwood has a variety of options.. I would be happy to use the original clutch pedal and have a master cylinder located on the underside of the cab. Totally open to options...
Any thoughts or pictures are appreciated.
Re: Hydraulic clutch pedal [Re: Yukon56] #1302872 Wed Mar 13 2019 11:46 AM
Grigg Offline
In my opinion if you can use a mechanical clutch linkage that should be first and best choice. Much less trouble in the long run than hydraulic.
1952 Chevrolet 3800 pickup
---All pictures---
Re: Hydraulic clutch pedal [Re: Yukon56] #1302889 Wed Mar 13 2019 02:53 PM
Y
yar Offline
Yukon,
A hydraulic clutch gives you no feedback through the pedal. You know the clutch is engaged when the vehicle starts moving forward or the engine stalls. Mechanical linkage gives real "feel" allowing precise engagement.
Ray
Re: Hydraulic clutch pedal [Re: Yukon56] #1302891 Wed Mar 13 2019 03:04 PM
Y
Yukon56 Offline OP
Thanks for the input.
I believe the NV3500 requires some sort of hydraulic clutch setup..but I could be wrong. I believe the bellhousing window is on the passenger side of the trans. I should have mentioned earlier what transmission I was going to be using.
I really do prefer the ''real feeling'' of clutch engagement...giving true feedback through the pedal.
Re: Hydraulic clutch pedal [Re: Yukon56] #1302982 Thu Mar 14 2019 05:54 AM
coilover Offline
1960-62 Chevy trucks came from the factory with hydraulic clutches that had the TO arm and slave cylinder on the passenger side, might check it out.
Evan
Re: Hydraulic clutch pedal [Re: Yukon56] #1303006 Thu Mar 14 2019 02:41 PM
Hotrod Lincoln Offline
Boltergeist
Do some homework on the diameter and stroke of the master and slave cylinders. A mismatch can result in either not enough pedal stroke to fully disengage the clutch, or possibly an extremely stiff pedal. Both cylinders, as well as the leverage of the pedal arm, have to work well together.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Hydraulic clutch pedal [Re: Yukon56] #1303011 Thu Mar 14 2019 02:48 PM
Y
Yukon56 Offline OP
Thanks fella's
With my research is appears the factory bore for a NV3500 was 18mm or .70. I will look into the 60-62 setups, and see what they came with for a MC bore. Wilwood offers a MC with a .75 bore, but I will be sure to match the MC to the slave cylinder regardless.
This is a very similar setup to what I was thinking, check out the link if you have time and feel free to comment on any pitfalls you may see with this idea...
Cheers!
http://forum.studebakerdriversclub....pedal-for-hydraulic-clutch&styleid=2
Re: Hydraulic clutch pedal [Re: Yukon56] #1303019 Thu Mar 14 2019 03:25 PM
mick53 Offline
I'm going with hydraulic throw out bearing also to eliminate clearance problems.
Re: Hydraulic clutch pedal [Re: Yukon56] #1303022 Thu Mar 14 2019 03:43 PM
Boltergeist
The round track cars we built with the small diameter triple disc clutch to decrease the rotating mass of the engine used a slave cylinder that was incorporated into the throwout bearing. That clutch assembly is only about 8" in diameter and it gets its torque carrying capacity by having three friction discs and two steel "floater" plates sandwiched between them. The whole assembly fits inside the bellhousing, mounting on the transmission bearing retainer. It's a neat, compact setup that should also work well on a street machine if the hydraulic throwout bearing is used with a conventional clutch. The triple disc clutch is sort of an on/off situation that doesn't respond well to an effort to make a smooth takeoff from a stop!
Re: Hydraulic clutch pedal [Re: Yukon56] #1303025 Thu Mar 14 2019 04:07 PM
Boltergeist
Search Ebay for "hydraulic throwout bearing". There's dozens of them listed, some at very reasonable prices.
Page 1 of 2 1 2
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.7.3
