The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Hotrod Lincoln, WE b OLD, Alainfrenchie54, glenns towing, RdsLessTaken, dhjmd), 131 guests, and 3 robots.
Forums50
Topics119,455
Posts956,431
Members43,405
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Hydraulic clutch pedal
Yukon56 #1305403 Sun Mar 31 2019 06:16 AM
I used an early '60s Chevy dual master cylinder (brake-clutch) on a '34 Ford pickup, along with the matching clutch slave cylinder. Unbelievably simple to set up - run the hard line anywhere you need to without hassling with routing mechanical linkage. Since then I'm sold on hydraulic clutch systems.
1951 Chevy Panel Truck
Yukon56 #1312348 Wed May 29 2019 06:50 PM
I know this thread was a couple of months back but just wanted to share some wisdom. I 'm putting a Muncie in my 59' and shopped around for a hydraulic clutch kit, plenty out there but most were out of budget (CHEAP). I found an assembly at Speedway that was completely bolt in (you may need to fab up a support bracket) they even had a master cylinder that matched the bore needed. All told I have about $200.00 in parts excluding the clutch disc and pressure plate. Still working out the under cab mount for the master cylinder as I wanted to keep the original pedal assembly. I'll post some pics when its completed.
Craig
Come,Bleed or Blister somethings got to give!!!
Q:"What yah runnin"
A:"3/8 drive Black and Decker aquarium pump motor" (the movie HOTROD)
59' Apache 31, long term project (30 years and counting)
miraclepieco #1314301 Fri Jun 14 2019 02:23 PM
Curious, did you use the bell housing with the passenger side access?
Page 2 of 2 1 2
Moderated by  KCMongo
