The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
20 members (55 SHAKER, archburycontrol, 76Buffalo, Big Diehl, 49 3100, CASO), 236 guests, and 3 robots.
Forums47
Topics117,634
Posts941,008
Members43,013
Most Online1,229
Jan 21st, 2020
Image Posting Policy
What is this part?
#1302616 Mon Mar 11 2019 01:31 PM
Joe S. Offline OP
On my '49 Chevy 3100 1/2 ton the part in the picture was under the bed and attached to an angle iron brace spanning between the frame members. It is obviously cut off. What function did it serve and what is it called?
best regards,
Joe
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
Re: What is this part?
Joe S. #1302624 Mon Mar 11 2019 02:47 PM
ace skiver
I cannot ID the part, Joe; however, my guess is that it was part of the spare tire carrier?
Is there a spare tire carrier under the bed?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Joe S. #1302628 Mon Mar 11 2019 03:06 PM
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Spare tire carrier piece. Too light of metal for part of a trailer hitch.
ā€˜65 Chevy Biscayne 4dr 230 I-6 one owner (Iā€™m #2)
ā€˜39 Dodge Businessmans Coupe
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Joe S. #1302644 Mon Mar 11 2019 04:39 PM
Truck Whisperer
Does not match spare tire carriers on Ebay. If it was attached to an add-on/non original "angle iron" cross member, it's not original. Also depends on where under the bed. Front middle rear. And what direction the cut off was facing. Except for light construction as Martin said, I would have guessed trailer hitch. But the part has unique, era correct form.
I'm away on an ego trip. Will be back on Feb 30.
I'm not an Auto Mechanic, but I play one on TV.
I charge $0.02 for every opinion and I take Paypal.
Plan B is always better than plan A, by definition.
Joe S. #1302683 Mon Mar 11 2019 11:33 PM
7
Maybe an add-on exhaust hanger.
1957 Chevrolet 5700 LCF 283 SM420 single speed rear, 1955 IH 300U T/A, 1978 Corvette 350 auto
Joe S. #1302691 Tue Mar 12 2019 12:12 AM
That is a section of a slider for spare tire carrier. Looks like most of it has been cut off
bartamos #1302715 Tue Mar 12 2019 03:13 AM
Where?? I need one (eventually).
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Joe S. #1302726 Tue Mar 12 2019 04:07 AM
Its what 52 Carl said. My truck still has the piece under it.
Joe S. #1302729 Tue Mar 12 2019 05:14 AM
Truck Whisperer
Kevin.......this is what I found for sale. Pic 1
https://www.ebay.com/itm/1-USED-ORI...DER-BED-SPARE-TIRE-CARRIER/153405156925?
Joe, as Carl confirmed and was said by others, It's the slider. It's a piece of what is sometimes called the "track", for the carrier.. Not shown in the Ebay pics.
Mounted just like you said. Pic 2
bartamos #1302825 Wed Mar 13 2019 12:13 AM
Thanks, but I have a '51 that takes the swing out style. I have one from a '72 Chevy that I may try to adapt. One of the members sent me some dimensions off his. thumbs_up
Moderated by  Fourbrads, HandyAndy
