The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
More great reading ...
Check this out!
Refueling the Past
Our very own
Archie
“46 Texaco”
Bentz
has a #1 ranked (on Amazon) book on Automotive History!
See link below for image.
REFUELING
THE
PAST
Find all the details here.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (coilover, fixite7, Gone, ArmyMike, bigedpa, 1 invisible), 152 guests, and 3 robots.
Forums60
Topics123,963
Posts1,000,381
Members44,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
front wheel bearing
#1302178 Fri Mar 08 2019 09:44 AM
hi,
i was going to change my front wheel bearing on my 1954 one ton.
the axle seems to be worn because the inner wheel bearing moves on the axle. is there a quick fix??? another smaller bearing? glue? Welding?
take care.
-morten-
Re: front wheel bearing
morten larsen #1302179 Fri Mar 08 2019 10:46 AM
Hello Morten,
Sounds like you have or had the wrong inner bearing. There was a change in 1952, up to 1952 1 ton trucks had an inner bearing ID of 1.41" after 1952 the one ton trucks inner bearing/cone is 1.51". Do you think somebody put earlier model spindle/hubs or complete front axle(smaller) on your 54 and you have the bigger bearings for the 1954 in there?
If it were my truck, I would use a micrometer and measure the spindle, then see if you ordered the correct bearings.
http://chevy.oldcarmanualproject.com/parts/1929_54/index.htm
https://www.classicparts.com/1936-52-Wheel-Bearing-3_4-1-ton-Front-Inner/productinfo/73-021/
https://www.classicparts.com/1953-59-Wheel-Bearing-3_4t-Frt-Inner/productinfo/73-022/
Steve
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
morten larsen #1302191 Fri Mar 08 2019 02:00 PM
noop, it is the corrects bearings. have been recommended loctite 638 somewhere else, will try that.
-morten-
morten larsen #1302198 Fri Mar 08 2019 02:29 PM
What is the size difference between bearing bore and spindle?
Using a loctite product (if within it's capabilities) may work but will likely keep the bearing from sliding off easily too, which means very difficult to remove the hub to do brake work and the seal will likely pull out of the hub before the bearing comes off the spindle.
Sometimes a part in better shape is the best fix, you might want to look for a spindle.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
morten larsen #1302245 Fri Mar 08 2019 09:07 PM
I had the same issue on a spindle too. Wish there was a repair sleeve that could be press fitted on the spindle for use on the earlier spindle - to convert it to the later and larger size bearing. I went the Loctite route but I wonder about he longevity of this repair. Since then I have kept my eyes out for NOS spindles. NOS door latches, hinges, and axle spindles seem to be the items that I keep an eye on.
tom moore #1302265 Fri Mar 08 2019 11:35 PM
Great idea Tom in my opinion. When it comes to bearings and clearances around races and machined spindles close isn't good enough.
1953 Chevrolet 3100
1964 GMC 1000
morten larsen #1302338 Sat Mar 09 2019 05:25 PM
How much clearance is there? Not guesswork or SWAG- - - -actual measurements! A dial caliper from Harbor Fright or Ebay is cheap insurance where safety of operation items are concerned. If there's not a visible amount of up and down slack, this doesn't sound like a problem. The inner bearing race is supposed to be a smooth slip fit on the spindle.
One possible fix would be an "Okie Knurl"- - - - -a bunch of center punch marks on the area where the bearing fits to slightly expand the spindle and take up some of the clearance. The right fix is to replace the spindle if the clearance is really excessive. With as many IFS butcher jobs as are being attempted these days, straight axles and component parts should be plentiful and cheap.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Grigg
