The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 registered members (55 SHAKER, Donf, Hotrod Lincoln, 59 fleet, BlueBolt, chevyfiftynine), 309 guests, and 3 spiders.
Forums47
Topics115,772
Posts920,119
Members42,336
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
wing vent window weatherstripping #1301973 Wed Mar 06 2019 08:54 PM
bluesman Offline OP
So, I've managed to get the wing vent assemblies back together, with one exception. I can't find the little rivets that hold the vertical strip in place. I'm talking about the part where the wing vent window closes against the vertical bar.
Does anyone know where to get those? Or what size they are? Or some sort of substitute?
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Re: wing vent window weatherstripping [Re: bluesman] #1301992 Thu Mar 07 2019 12:26 AM
bartamos Offline
This may or may not help but seems possible.
https://www.classicparts.com/1951-87-Vent-Assembly-Rivets/productinfo/03-825
https://www.classicparts.com/1951-87-Vent-Rivet-Setting-Tool/productinfo/03-835/
When restoring a truck, one needs to get familiar with vendors who specialize in the parts. Get good at searching those vendor sites. This took less than 12 parsecs to find.
No problem, just FYI. You can thank your Lucky Stars I'm here. Whether you own a "Mercury Comet", a Chevy "Astro" or a Plymouth "Satellite", parts are in this Galaxy. (sorry, I read your profile)
Laziness is the Father of invention.
Re: wing vent window weatherstripping [Re: bartamos] #1302002 Thu Mar 07 2019 01:12 AM
Jay Zed Offline
Ha ha, good stuff!
Re: wing vent window weatherstripping [Re: bluesman] #1302003 Thu Mar 07 2019 01:15 AM
52Carl Offline
Lots of guys just glue those in place. I would recommend black urethane sealant, and use some clamps to hold the seal in place until the sealant cures.
Re: wing vent window weatherstripping [Re: bluesman] #1302006 Thu Mar 07 2019 01:25 AM
MNSmith Offline
I just used some small blind rivets. Stainless, so they wouldn't rust.
Re: wing vent window weatherstripping [Re: bluesman] #1302012 Thu Mar 07 2019 01:41 AM
Achipmunk Offline
I'll have to go with Carl on this one.....been running glued on pieces like you describe for years...no problems and the rivets can be a pain in the back side. I gave up on mine, the rivets were so hard you couldn't set them and the little tool I bought with them was useless/worthless. Your choice though.
Pictures in my Photobucket
52 Chevy Panel
Re: wing vent window weatherstripping [Re: bluesman] #1302014 Thu Mar 07 2019 01:45 AM
bartamos Offline
I did see that Classic also had SS.
Re: wing vent window weatherstripping [Re: MNSmith] #1302025 Thu Mar 07 2019 02:11 AM
bartamos Offline
Blind rivets have a stick out. How does that work on a division bar where both sides need flush? Also aren't the rivet sizes predetermined by the hole and countersink sizes?
I only know TF. Maybe AD is different, just curious.
Re: wing vent window weatherstripping [Re: bluesman] #1302031 Thu Mar 07 2019 02:50 AM
tclederman Offline
Boltergeist
I used the tool and rivets that batamos posted.
After screwing-up one into oblivion, all the rest were quite easy to install.
I know what to do on the truck I should be restoring.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 48 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: wing vent window weatherstripping [Re: bluesman] #1302044 Thu Mar 07 2019 04:48 AM
Fox Offline
Tim, I used the classic rivets and I found the installation to go fairly smoothly. Like Tim said aw well, i screwed up the first rivet (not in the frame though, it was on my vise) and then got the feel for the tool and it went easier after that. One good thing about the kit was that it came with a couple extra rivets and I suspect it was exactly for this reason!
More pictures here
1953 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: wing vent window weatherstripping [Re: bartamos] #1302047 Thu Mar 07 2019 05:04 AM
MNSmith Offline
It's been a while, but there must be space on the backside. The channel felt sits where it is supposed to and I have no window bind. I must've checked fitment before I used them.
Re: wing vent window weatherstripping [Re: bluesman] #1302048 Thu Mar 07 2019 05:43 AM
bartamos Offline
That would sure be a lot easier. I will check that method next time. Is that the head side? I was thinking of the upset end stick out. Must be clearance as you say.
Re: wing vent window weatherstripping [Re: bartamos] #1302113 Thu Mar 07 2019 09:29 PM
MNSmith Offline
Yes.
Page 1 of 2 1 2
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.7.3
