The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (53 in Phoenix, Greg Brown, chevyb, carbking, 55_2nd_Series, 3B), 95 guests, and 3 robots.
Forums50
Topics119,481
Posts956,707
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Now What?
#1301556 Sun Mar 03 2019 05:20 PM
Ive just found out that my offy 4bbl intake will not fit up to the Massey Ferguson 292 exhaust that I bought on EBay. Ive removed as much stock as I can from the bottom of the intake and the top of the exhaust...still don’t mate well...has anyone else run into this?
Re: Now What?
floaterboy #1301568 Sun Mar 03 2019 07:40 PM
I had same problem old Clifford intake, as long as they are close you should be fine. I had to add a plate to stock exhaust to fill up the space, not bolted together. Problem with this Clifford was that it was not a good fit at all to intake runners but I made it work. I went with a Remflex brand thick gasket (sold by Summit) between manifolds and head which made up for poor fit.
Best of luck
Jim
http://catalog.remflex.com/
1946 1/2-Ton Chevy
Re: Now What?
floaterboy #1301575 Sun Mar 03 2019 08:33 PM
I'm just asking questions: how did you remove material from the intake and exhaust manifolds? Before you did that were they misaligned, or did they interfere with each other?
Professional Novice
Re: Now What?
floaterboy #1301579 Sun Mar 03 2019 08:43 PM
Thanks for the reply. Someone on this forum said this would work. The runners on the exhaust are huge! The intake sits too high to mate with the head and “heat riser” section of the exhaust. Is this same issue you had? What did you use for a plate between them?
Len
Re: Now What?
Frank50 #1301592 Sun Mar 03 2019 09:49 PM
Frank,
I removed the stock with a sanding disc on a die grinder. The runners on the exhaust were too high. That’s what caused the intital misalignment. The intake literally sat on top of the exhaust runners.
Re: Now What?
floaterboy #1301640 Mon Mar 04 2019 02:49 AM
If you could post a photo would be a big help. It's common to have to do surgery on aftermarket manifolds, everyone I've had turned into a project. I had a chunk of maybe 1/8" flat stock I cut to fit the intake to exhaust, and using counter sunk machine screws I was able to make it work and fit just to the exhaust half.
Also do check out this Remflex stuff, I'll attach a page from their catalog on 292 inlines. http://catalog.remflex.com/CHEVROLET_GM_CHEVY_Header_Exhaust_Manifold_Gasket_p/2034b.htm
1946 1/2-Ton Chevy
Moderated by  Woogeroo
