New Forum Added in Parking Lot
EARLY BOLTS
1916 - 1936
1928 Chevrolet AB Canopy Express "Justin"
Discussing issues specific to the pre-1937 trucks.
Forums64
Topics122,558
Posts989,211
Members46,963
Most Online1,229 Jan 21st, 2020
#130115
Wed Jan 16 2002 10:30 PM
OP
I want to remove the fuel tank from the cab of my 62 c-10 and mount one under the bed. I have looked at custom made to order aluminum tanks and also the pre-fab poly tanks sold by Brothers and GMC Paul as replacement tanks for Blazers and Suburbans. Brothers says the tank can be used for 63-66 Chevy truck under bed mounting and GMC Paul sells a similar, if not the same, tank advertised for 60-66 Chevy's. I have been told the width of the frame is the issue in making these pre-fab poly tanks work with my truck. The tank is 26" wide and my frame is about 37" wide. I am considering using the poly tank simply because it is a reproduction GM part and might be easier to work with than a custom aluminum tank (i.e. corrosion resistant, off the shelf parts, no painting required, etc). Has anyone installed one of the poly tanks? What kinds of frame modifications had do be done to box it in. I really need a lot of input on this because I don't where to start if I have to add support to the frame.
#130116
Mon Jan 21 2002 12:38 AM
I had a 13 gallon custom aluminum fuel tank made for a 48 pickup by a local fab shop for less than the cost of one of those poly tanks. Its got a neat filler that comes up flush to the bed (which may not work for you). It uses my factory sending unit and works great. I'd check you local fabricators and welders and ask around at your local speed shop.
Chris
