The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 registered members (Jimmie D, 53 green 1- ton, reidy, Frank50, Doug 57, 1 invisible), 270 guests, and 3 spiders.
Forums48
Topics117,364
Posts938,467
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Wrong flexplate? #1299322 Sun Feb 17 2019 02:41 AM
floaterboy Offline OP
I tried to install the starter and it was a no-go.https://www.stovebolt.com/ubbthreads/images/icons/default/frown.giftThe shaft that the starter gear turns on appears to contact the flexplate. I’m guessing I have a 168 tooth instead of a 153 tooth? Is there another starter I can use or do I need to change the flexplate?
Re: Wrong flexplate? [Re: floaterboy] #1299342 Sun Feb 17 2019 02:42 PM
tclederman Offline
Boltergeist
What type/year/application (car/truck) engine and automatic transmission do you have?
Wrong Flexplate?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Wrong flexplate? [Re: floaterboy] #1299366 Sun Feb 17 2019 05:12 PM
1965 Chevy 230 car engine backed with a 2004r. I bought the motor w/o the flexplate and ASSUMED I needed a 168 tooth. Now the starter will not fit due the larger diameter of the flexplate.
Re: Wrong flexplate? [Re: floaterboy] #1299370 Sun Feb 17 2019 06:04 PM
Hotrod Lincoln Offline
Boltergeist
You assumed wrong. Try measuring the distance from the center of the crankshaft to the starter pinion gear without the flex plate installed, and choose a plate that approximates that diameter. It's the old "measure twice- - - -cut once" concept.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
