The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Some light reading
ENTERTAINING ADVENTURES
In the Stovebolt Reading Room
A little light reading
OR
Epic stories of old tin hunting!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (archburycontrol, DougH6100, dirtball, 68ironhead, Erik Husker, dschmit), 391 guests, and 3 spiders.
Forums48
Topics117,365
Posts938,474
Members42,915
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Wrong flexplate? #1299322 Sun Feb 17 2019 02:41 AM
floaterboy Offline OP
I tried to install the starter and it was a no-go.https://www.stovebolt.com/ubbthreads/images/icons/default/frown.giftThe shaft that the starter gear turns on appears to contact the flexplate. I’m guessing I have a 168 tooth instead of a 153 tooth? Is there another starter I can use or do I need to change the flexplate?
Re: Wrong flexplate? [Re: floaterboy] #1299342 Sun Feb 17 2019 02:42 PM
tclederman Offline
Boltergeist
What type/year/application (car/truck) engine and automatic transmission do you have?
Wrong Flexplate?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Wrong flexplate? [Re: floaterboy] #1299366 Sun Feb 17 2019 05:12 PM
1965 Chevy 230 car engine backed with a 2004r. I bought the motor w/o the flexplate and ASSUMED I needed a 168 tooth. Now the starter will not fit due the larger diameter of the flexplate.
Re: Wrong flexplate? [Re: floaterboy] #1299370 Sun Feb 17 2019 06:04 PM
Hotrod Lincoln Offline
Boltergeist
You assumed wrong. Try measuring the distance from the center of the crankshaft to the starter pinion gear without the flex plate installed, and choose a plate that approximates that diameter. It's the old "measure twice- - - -cut once" concept.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
