Forums47
Topics113,252
Posts897,972
Members41,570
Most Online940 Apr 5th, 2017
Anyone want a brand new 250 six?
#1298268
Sun Feb 10 2019 12:10 AM
OP
Dallas, TX
All you have to do is figure out how to get around the EPA regulations, come up with $2500 and off you go... http://www.donhardyengines.com/specials.htm (bottom of the page)
Jon
1952 1/2 ton with 1959 235 T5 with 3.07 rear end
Re: Anyone want a brand new 250 six?
[Re: Jon G]
#1298280
Sun Feb 10 2019 02:07 AM
He mentions EPA regs for stationary engines, which are getting pretty tough. But you could put it in a truck and keep moving so the EPA can't find you.
Kevin First car '29 Ford Special Coupe #2 - '29 Ford pickup restored from the ground up. Newest Project - 51 Chevy 3100 work truck.
[Re: Jon G]
#1298282
Sun Feb 10 2019 02:25 AM
Plano, Tx
Been a long time since I've heard that name. He is up in the Texas Panhandle and used to build dragster chassis for some top names.
Evan
[Re: Jon G]
#1298284
Sun Feb 10 2019 02:36 AM
Evan- - - -have you ever heard of a truck/tractor pull engine builder named Jerry Janke? I believe he was in southwest Texas at one time, several years ago. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
[Re: Jon G]
#1298327
Sun Feb 10 2019 03:21 PM
With the price of machining and parts now, $2500 is a pretty good deal for what you are getting. The exhaust manifold is worth quite a bit by itself.
[Re: klhansen]
#1298328
Sun Feb 10 2019 03:25 PM
IL
He mentions EPA regs for stationary engines, which are getting pretty tough. But you could put it in a truck and keep moving so the EPA can't find you.  Very interesting. That's the first I've seen anyone list industrial engines. I wonder if they come with the stand and radiator assembly too. Keep it for a test stand. Not bad prices. A big block can be had for less than $3K. I do know from the Generac units that I've installed, the distributor is locked down with no advance. They are governed at 1800 rpm too, so I'm guessing they have a very mild cam. Still, not bad for crate engines. As far as emissions, probably not an issue if they're going into a 60 year old truck.
[Re: Jon G]
#1298340
Sun Feb 10 2019 04:25 PM
I'd have a hard time spending $2500.00 rebuilding a 3rd. generation stovebolt engine, especially since I do virtually all my own machine work. Then again, I also build my own firearms. In either case, the "government" can go pound sand! Jerry
[Re: Jon G]
#1298479
Mon Feb 11 2019 09:21 AM
Plano, Tx
Jerry, Yes, there were several pull trucks and tractors running the very good Janke engines. We used Aires which are basically BBC short blocks with Hemi heads. The wedge head engines are strong out of the hole and on times the track was right the hemi's big top end power couldn't overcome the wedges hole shot.
Evan
[Re: Jon G]
#1298515
Mon Feb 11 2019 05:18 PM
I knew Jerry back in the late 1970's when he was a maintenance supervisor at E & J Gallo winery in Livingston California. I worked there as a maintenance mechanic/pipefitter before moving back home to Tennessee in 1980. I believe he started building puller engines shortly after that, after moving to Texas. At that time he was driving a very highly modified 56 Ford pickup, the really scarce one with the wraparound rear window. I never got a look under the hood, but it had ladder-style traction bars, and sounded like it needed them.
Wasn't the Aires engine an aluminum-block clone of the BBC? If I remember correctly, didn't Donovan build an aluminum clone of the early MOPAR hemi? Jerry
