The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (55_2nd_Series, HandyAndy, BC59, DennisM, 2 invisible), 314 guests, and 3 spiders.
Forums47
Topics116,131
Posts923,450
Members42,352
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297140 Fri Feb 01 2019 06:11 AM
Fox Offline
Im also glad to hear you got it out. I have been watching this thread and couldn’t wrap my head around how to solve it either without major damage. Good job. Newly rebuilt hinges go a long way to helping these old doors.
I love that sound of the door closing. It makes me smile every time too!
More pictures here
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297192 Fri Feb 01 2019 11:10 PM
Snowman51 Offline OP
On a side note- what are the hold open spring holes in the hinge( the cast j-shaped piece) suppose to look like? As I look down on the hinge, I see the hole for the hinge pin and the hole for the spring. That hole has a little groove trailing from the spring hole. Is it suppose to be there? I looked at the other side spring hole and it had one too. Is this crucial for the function of the hold open feature or should I weld it flat, leaving the spring hole?
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297196 Fri Feb 01 2019 11:35 PM
Dusty53 Offline
Snowman51 - take a look at this YouTube Video. It was very helpful to me when I "overhauled" the door hinges on my 1954 3600.
https://www.youtube.com/watch?v=qKEOVGxcVpI
Good luck, time and patience are your friend.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297283 Sat Feb 02 2019 05:41 PM
I saw it- you’re right. Very helpful. Looks like I need do to some welding, drilling, and filing. Thanks to all for helping me solve this. I’m looking forward to the solid thunk of the door closing!
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297330 Sat Feb 02 2019 10:15 PM
Back again. Upon looking for correct drill bits for hinge frame and hinge arm ( I assume the cast j-shaped piece). I have found conflicting suggestions (Deve says 11/32 for arm and R for hinge frame in one post, then 11/32 for hinge frame and R for arm in another??). Can anyone straighten me out? What are the correct drill sizes? I also saw the spring holes in the arm are 15/64”.
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297357 Sun Feb 03 2019 01:06 AM
52Carl Offline
The correct size is dependent on the size of the replacement pin diameter. The kits that I have bought, provide information as to what size drill bit to use.
Page 2 of 2 1 2
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.7.3
