The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 registered members (51Craig1Ton, jorb, edwardsss, Justhorsenround, JD1, 1 invisible), 319 guests, and 2 spiders.
Forums47
Topics115,013
Posts912,548
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 2 1 2
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297140
Fri Feb 01 2019 06:11 AM
Fox  Offline
Breton, Alberta
Im also glad to hear you got it out. I have been watching this thread and couldn’t wrap my head around how to solve it either without major damage. Good job. Newly rebuilt hinges go a long way to helping these old doors.
I love that sound of the door closing. It makes me smile every time too!
More pictures here
1953 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- rusted
1970 Chevrolet K20 Suburban—rusted.
1950 Chevrolet 1300- in progress to shiny.
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297192
Fri Feb 01 2019 11:10 PM
Snowman51  Offline OP
Idaho Springs, CO
On a side note- what are the hold open spring holes in the hinge( the cast j-shaped piece) suppose to look like? As I look down on the hinge, I see the hole for the hinge pin and the hole for the spring. That hole has a little groove trailing from the spring hole. Is it suppose to be there? I looked at the other side spring hole and it had one too. Is this crucial for the function of the hold open feature or should I weld it flat, leaving the spring hole?
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297196
Fri Feb 01 2019 11:35 PM
Dusty53  Offline
North East Missouri, USA
Snowman51 - take a look at this YouTube Video. It was very helpful to me when I "overhauled" the door hinges on my 1954 3600.
https://www.youtube.com/watch?v=qKEOVGxcVpI
Good luck, time and patience are your friend.
Ronnie
1954 Chevy 3604 - A work in progress...
" You can't keep dancing with the Devil and wonder why you're still in hell"
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297283
Sat Feb 02 2019 05:41 PM
Idaho Springs, CO
I saw it- you’re right. Very helpful. Looks like I need do to some welding, drilling, and filing. Thanks to all for helping me solve this. I’m looking forward to the solid thunk of the door closing!
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297330
Sat Feb 02 2019 10:15 PM
Idaho Springs, CO
Back again. Upon looking for correct drill bits for hinge frame and hinge arm ( I assume the cast j-shaped piece). I have found conflicting suggestions (Deve says 11/32 for arm and R for hinge frame in one post, then 11/32 for hinge frame and R for arm in another??). Can anyone straighten me out? What are the correct drill sizes? I also saw the spring holes in the arm are 15/64”.
Re: 51 3100 trouble with door hinge removal [Re: Snowman51] #1297357
Sun Feb 03 2019 01:06 AM
52Carl  Offline
Virginia
The correct size is dependent on the size of the replacement pin diameter. The kits that I have bought, provide information as to what size drill bit to use.
Page 2 of 2 1 2
Moderated by  48bigtrucks
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
