The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Justhorsenround, 1929chevydave, Tiny, Hambone, tclederman, SWEET), 85 guests, and 3 robots.
Forums50
Topics119,467
Posts956,550
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: LED Workshop Lights?
Paul_WNC #1295345 Fri Jan 18 2019 10:59 PM
Andy
The ones I got just directly replaced the tubes. No ballast removal at all.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
Paul_WNC #1295379 Sat Jan 19 2019 04:33 AM
If you have T5 fluorescent don’t buy new fixtures.
Many of the new “LED” fixtures are same old fluorescent fixtures simply without any ballast.
If the LED tubes you choose will operate without a ballast, most will, then you’re better off sniping out your ballast and wiring direct. You don’t need to physically remove it if you don’t care to.
1951 GMC 250 in the Project Journals [stovebolt.com]
1948 Chevrolet 6400 [stovebolt.com] - Detroit Diesel 4-53T - Roadranger 10 speed overdrive - 4 wheel disc brakes
1952 Chevrolet 3800 pickup [stovebolt.com]
---All pictures [picasaweb.google.com]---
Paul_WNC #1295536 Sun Jan 20 2019 01:53 PM
Hey all,
Thanks for the great input on the LED lights. Good to hear that those that have made the switch are happy with the light quality produced from the LED style bulbs. I went to our local Lowes yesterday in attempt to see some LED shop lights on display. Unfortunately in spite of the giant size of the store, they had little LED shop light inventory and no working display. They were not cost competitive with online vendors either. As of now, I believe my choice of direction is to replace all of the old fixtures with ones that are designed to function with LED bulbs as my existing fixtures are the simple (cheap) units that hang from a chain. The problem is that I have (16) - two bulb fixtures so it will cost a bit to make the change. You all have equipped me with much more information and resources to study, now all that is needed is some comparison shopping. Thank you to all that have responded.
Paul
Paul_WNC #1295580 Sun Jan 20 2019 06:48 PM
Do your existing fixtures have 4’ bulbs? If so probably don’t have to change the fixtures.
Paul_WNC #1296460 Sun Jan 27 2019 05:24 PM
Where do you find type B bulbs? Home depot and Lowes only carries type A, which only work with the ballast connected. I currently am steadily having more and more ballasts going out on me.
I like my fluorescent lighting just fine. Multiple failing ballasts, not so much.
Paul_WNC #1296468 Sun Jan 27 2019 05:50 PM
Carl, you will like the instant bright when turning the LEDs on.
A buddy of mine just put some on the wall to help with painting the sides of his car, he was more than happy with the amount of light a definite plus over the fluorescent lights.
1953 Chevrolet 3100
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
1964 GMC 1000
Grigg #1296497 Sun Jan 27 2019 09:14 PM
Originally Posted by Grigg
These bulbs, https://www.prolighting.com/catalogsearch/result/?q=GL07103-2M
We chose the 4000 instead of the 5000 because the softer (less blue) seemed better...
These bulbs wire from one end or both, direct wired 120V or with existing ballast. Keep it simple and more efficient by direct wiring them, from one end.
Paul_WNC #1296504 Sun Jan 27 2019 09:45 PM
Thanks Grigg!
Paul_WNC #1296508 Sun Jan 27 2019 10:03 PM
You’re welcome, and try this.
7% off coupon code GARAGEJOURNAL
Paul_WNC #1296608 Mon Jan 28 2019 03:24 PM
V
VEW Offline
I put the FEIT LED's in my shop a couple years ago. Started with just two and then just kept adding them because I "saw the light". I've got them everywhere now. A tube in two of the fixtures failed several months ago. I didn't think they were supposed to do that. They are self contained, so not replaceable (they say). Anyway, I contacted FEIT just for the heck of it. Their rep confirmed that my thinking was correct. They asked where I got them (Costco), how many I have, and asked for my address. They sent me two new ones ----no charge!
Victor
41 3/4 Ton Pick Up (in process)
55 Grumman Kurbside (Doughboy) 235/3 on tree w/ OD
57 3100
58 C4400 Viking (Thor)
59 C4500 Short Bus (Magic Bus)
59 G3800 1 Ton Dually (Chief)
Page 2 of 3 1 2 3
Moderated by  48bigtrucks, MNSmith
