The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Hotrod Lincoln, DoubleDingo, BC59, 3800GUY, BLUEMEANIE, 1 invisible), 103 guests, and 4 robots.
Forums50
Topics119,481
Posts956,703
Members43,409
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1949 suburban ignition switch removal
#1294907 Mon Jan 14 2019 11:43 PM
Guys, it has been ages since I was here, need some info on removal of a stock ignition switch for a 1949 suburban ignition switch and no keys are currently available, do these simply unbolt from dash then remove 3 wires? I can get key made at locksmith for $20 if I bring him the ignition switch, I just can't recall after 20 years not touching one. I will post pictures of the runner/driver burb I'm moving for storage. Thanks guys for any help!
Re: 1949 suburban ignition switch removal
10 micron #1294922 Tue Jan 15 2019 01:30 AM
ace skiver
https://www.classicparts.com/1947-53-Ignition-Switch-Original-Style/productinfo/53%2D405/
https://www.classicparts.com/1947-53-Ignition-Switch-Bracket/productinfo/53%2D461/
The bracket attaches to the rear of the dash.
As I dimly reall, the switch is twisted to catch the two posts.
I do not recall if there is an attachment nut/scew(s) for the switch to the bracket.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE [1954advance-design.com] - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
10 micron #1294943 Tue Jan 15 2019 04:24 AM
If you want to send me your orig. switch, I could come up with a key for you.
10 micron #1294981 Tue Jan 15 2019 07:13 PM
Thanks guys for the help, I can get one local for $20, wish I could find my stash of keys and I could get one for $2 at Wal-Mart
10 micron #1295017 Wed Jan 16 2019 01:45 AM
Two clutch head screws hold the ears of the switch on. Disconnect the battery ground! Loosen the 2 screws somewhat and turn the switch counterclockwise a bit and pull it out.
Moderated by  tclederman
