The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (66flea, 47fivewindow, D B Cooper, Hambone, 2 invisible), 246 guests, and 4 robots.
Forums47
Topics117,641
Posts941,062
Members43,016
Most Online1,229
Jan 21st, 2020
Image Posting Policy
38 Window channel felt
#1294545 Sat Jan 12 2019 04:26 PM
Chasz Offline OP
The existing metal/felt window channel (I believe it to be original) only runs to the top of the window on my 38 truck. At the radius of the window and across the top, the channel appears to become solid felt. I need to replace the channel but all I see for replacement material is the flexible steel/fuzzy channel. Should I just us that material in a continuous run up the back,over the top, and down the front?
Re: 38 Window channel felt
Chasz #1294625 Sun Jan 13 2019 12:16 AM
I used one continues piece on my 37 that I just installed. Worked great , just had to do a little forming on the corners. Ordered it from Chevs of the 40's
Chasz #1294817 Mon Jan 14 2019 06:20 AM
I also used the one piece " fuzzy channel " up, over, and down. Let it extend into the door a bit as well. As I recall, there are tabs inside the door to hold it.
Chasz #1294937 Tue Jan 15 2019 03:38 AM
Chasz Offline OP
Thanks guys!
Moderated by  48bigtrucks
