The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (BC59, beltfed, 2ManyTrucks, 49nut, 51 3804, campbell45), 322 guests, and 2 spiders.
Forums47
Topics115,030
Posts912,759
Members42,085
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 4 1 2 3 4
Other wheel Options for 1.5 ton trucks #1294568
Sat Jan 12 2019 06:45 PM
Philipj  Offline OP
FL
Hello All,
As you are all aware, the older rims and tires can be problematic to service or disassemble after being in use for 80 years... My solution to the issue was to have a new rim made to take care of the problem... I have found a company in California that will produce a rim similar to a Dodge Power Wagon for $ 245.00, but without any holes, and much like the rare 10.5 x 16 rim fitted to Canadian trucks sold for export...
The 10.5 x 16 rim might require modifying the fenders up front for the wider tires, but, I am willing to compromise and go with a narrower wheel up front 8" or 9" and not have to widen the fender by 4.75" and yet still have a wider tire fitted.. Another option would be to have staggered wheels... 8" up front and 10" in the rear. Opinions/information welcomed regarding suitable tires as well....Thank you.
Philippe Jeanneau
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1294641
Sun Jan 13 2019 01:19 AM
EdPruss  Offline
Longmont, CO
What is your wheel bolt pattern on your truck?
Ed
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1294674
Sun Jan 13 2019 04:33 AM
Philipj  Offline OP
FL
10 x 7.25 with a 4 -3/4 center bore...
Philippe Jeanneau
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1294710
Sun Jan 13 2019 02:18 PM
EdPruss  Offline
Longmont, CO
Late '50's 22.5 tubeless wheels will fit with a hub spacer, easily made. Fit 9 x 22.5 tires well. Somewhat hard to find, look on farm trucks. A gentleman in Az had some modern 22.5's with that kind of centers made by some wheel CO.
Ed
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1294720
Sun Jan 13 2019 03:22 PM
Philipj  Offline OP
FL
Hello Ed, thank you for the suggestion... It would be interesting to see details and photos from this gentleman in AZ. For now it seems easier for me to have new wider wheels made for my truck since I want to convert it to a Long Range Desert Patrol configuration...
DSC_2664 - Copy.JPG (298 downloads)
Philippe Jeanneau
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1294795
Mon Jan 14 2019 02:18 AM
EdPruss  Offline
Longmont, CO
He has a blue AD truck with black wood bed sides, look in old WOT or last couple years of Show Time.
Ed
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1308018
Sun Apr 21 2019 03:33 PM
Philipj  Offline OP
FL
Finally making some headway with the new wheel set-up... Backspaces for both front and rear are sorted and the new rubber has finally arrived also!
DSC_3497 - Copy.JPG (213 downloads)
DSC_3546 - Copy.JPG (218 downloads)
DSC_3565 - Copy.JPG (206 downloads)
Philippe Jeanneau
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1309278
Thu May 02 2019 05:23 PM
retro-roco  Offline
Bloomington, IL
Following...
WW2Chevy
(Retro-roco)
Re: Other wheel Options for 1.5 ton trucks [Re: retro-roco] #1309316
Thu May 02 2019 11:40 PM
Philipj  Offline OP
FL
Well, I can tell you I am very happy with the outcome so far... The wheels really make the truck look much better than before.
DSC_3608 - Copy.JPG (137 downloads)
DSC_3626 - Copy.JPG (136 downloads)
DSC_3628 - Copy.JPG (136 downloads)
DSC_3623 - Copy.JPG (139 downloads)
DSC_3630 - Copy.JPG (136 downloads)
Philippe Jeanneau
Re: Other wheel Options for 1.5 ton trucks [Re: Philipj] #1309318
Thu May 02 2019 11:42 PM
Philipj  Offline OP
FL
The only other thing to do is to drill the extra 5 holes on the front hub and install the studs...
DSC_3633 - Copy.JPG (133 downloads)
Philippe Jeanneau
Page 1 of 4 1 2 3 4
Moderated by  69Cuda, Grigg
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
