The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Planning for 2019
The Stovebolt Staff drives on to a NEW YEAR
Sincere thanks to all of you who contribute to the site in the various ways.
Keep your eyes on those gauges in
2019
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
1 registered members (chuck2213), 207 guests, and 3 spiders.
Forums47
Topics113,002
Posts894,885
Members41,486
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Rear end transmission options 1950 3/4 #1293164
Tue Jan 01 2019 10:16 PM
Tight_linesFL  Offline OP
FLORIDA
New to the site.
I know you guys have covered this over and over. And I've read so many articles about engine, transmission, and rear end.
I just brought home a 47-55 3/4 frame with the mustang ii suspension work already fabricated.
First question:
Even though the 3/4 ton rear end was shorter than the 1/2 could I still use an explorer rear end and adjust the tire width? With that in mind I'd like to also point out I would like to use a 383 stroker or 454 back by a muncie 4 speed (would love a t56 or tko600 but they're not in my budget). Everywhere I go they say good and bad thing about different combos. I'm not trying to race or anything but i want the hp to be there.
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1293171
Tue Jan 01 2019 11:05 PM
EdPruss  Offline
Longmont, CO
For safety and other considerations it is best not to put overly wide tires and wheels on a half ton rear axle. GM 14 bolt rear axles (6 or 8 lug) are cheap, plentiful, lots of ratios, disc brakes.
Ford 9" axles would work with IFS, too.
Ed
Re: Rear end transmission options 1950 3/4 [Re: EdPruss] #1293175
Tue Jan 01 2019 11:35 PM
FLORIDA
Thank you for the response. I know everything that will work on a half ton truck. But can I use the 60" rear end on a 3/4 ton AD? I know the 3/4 came stock with a 52" rear. But in theory if the box is the same width as a half ton it shouldn't matter, right? Maybe I'm missing something.
Brandon
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1293180
Wed Jan 02 2019 12:29 AM
FLORIDA
Thanks for the reply. I guess my real question is, will I be able to use a 60" on a 3/4 ton bed/frame. The 3/4 stock were 52" but if the width of the bed is the same as a 1/2 it shouldn't present an issue, right?
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1293211
Wed Jan 02 2019 04:50 AM
Whitedog  Offline
IL
I'm actually doing something similar as you with my 54 3600. IFS, Explorer rear.
You shouldn't have any trouble with the Explorer rear. There's probably a few thousand vintage trucks running around with them.
You're right, the bed is the same width on the 3100 up to 3800 trucks. The big difference is in the frame. The 3600 trucks have a narrower frame in the rear and they are spring-over axle vs. spring under axle.
With the narrower axle, you'll have to go conservative on your wheel backspacing and tire width, unless you plan on tubbing the bed or widening fenders. I haven't got my rear installed yet, just the IFS, so I can't really help on what backspace you'll need.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1293223
Wed Jan 02 2019 12:53 PM
FLORIDA
Thank you for your Input. That's exactly what I was looking for. It's been tough trying to find answers to my questions about 3600. Get me updated if you run into any other issues. Likely for myself the IFS was already installed in fabricated on the frame So that Avoids that headache
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1293735
Sun Jan 06 2019 01:09 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
I sincerely hope that M-II setup isn't one of the ones that puts the front bumper a couple of inches off the ground. Besides making the truck look like a hound dog that's just had a close encounter with a skunk, it won't really matter what kind of rear axle you install. The truck will be a hazard to navigation at any speed above parking lot cruising.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1293901
Mon Jan 07 2019 05:43 AM
coilover  Offline
Plano, Tx
The Explorer rear is 58" wide which is 3" wider on each side from a 52" rear. If heavy loads are in the picture you might consider going with the "C" clip eliminator kit. we have had good luck with the 8.8 Ford rear, both open and limited slip. The book shows a lot of different ratios but the ones we get are usually 3.73.
Evan
Re: Rear end transmission options 1950 3/4 [Re: coilover] #1293960
Mon Jan 07 2019 09:35 PM
FLORIDA
I'm looking at the same Gear ratio in the one I'm buying. I'm not really looking to do any hauling I have a work truck for that. I've looked into the eliminators but found with the disk brakes they are not necessary.
Re: Rear end transmission options 1950 3/4 [Re: Tight_linesFL] #1294507
Sat Jan 12 2019 05:44 AM
Whitedog  Offline
IL
The 8.8 is plenty strong. My 2009 truck with an 8.8 has a GAVW rating of 6900 lbs. In my book, not too shabby. I know Ford de-rated the Explorer 8.8 slightly because they use the smaller 5x4.5 wheel and tire combo, but everything else about the axle is equivalent. We're putting them in a 3500lb truck, I think it'll do just fine. Even an older 28 spline version will do the trick. The Mustang guys beat up on them for years. As far as the C-clip eliminators go, I don't see the point unless you're doing a 10 second pass or rock-crawling.
"The Fake Truck"
Page 1 of 2 1 2
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
