The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Links | Events | Features | Search | Hoo-Ya Shop
Planning for 2019
The Stovebolt Staff drives on to a NEW YEAR
Sincere thanks to all of you who contribute to the site in the various ways.
Keep your eyes on those gauges in
2019
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Some New
Some Vintage
Many in Production
Check for details!
Will be updating all year around!
1 registered members (chuck2213), 207 guests, and 3 spiders.
Forums47
Topics113,002
Posts894,885
Members41,486
Most Online940
Apr 5th, 2017
Image Posting Policy
37 Chev 1/2 ton stake pocket removal #1294336
Fri Jan 11 2019 12:33 AM
Bill Trotter  Offline OP
Iron River Mi.
Have a damaged driver side rear stake pocket with severe damage. What is the best way to remove these? I think they are spot welded but cannot see any of the welds. Would I be better off trying to straighten the damaged bottom of the bracket, or is there a trick to remove it? Thanks for any help with this. Bill
Re: 37 Chev 1/2 ton stake pocket removal [Re: Bill Trotter] #1294338
Fri Jan 11 2019 12:39 AM
klhansen  Offline
Eagle River, Alaska
Take some sandpaper and scrub along the flanges where they're fastened to the bed side. That should bring up the location of the spot welds. Then take a spot weld drill (flat tip twist drill or like a small hole saw with a pilot pin) and drill from the stake pocket side. Weld the replacement on using plug welds (holes in the new pocket filled with weld when clamped to the bedside.
Straightening the stake pocket would be tough, as it's at least 16 gauge metal. Pretty hard to work the damage out, especially with close quarters inside the pocket.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck.
Re: 37 Chev 1/2 ton stake pocket removal [Re: Bill Trotter] #1294342
Fri Jan 11 2019 12:58 AM
Iron River Mi.
Thanks for the tip. Approximately how many spot welds are there? Just removed my angle strips today and there were 34 to grind off. Gave my air compressor a good workout. Bill
Re: 37 Chev 1/2 ton stake pocket removal [Re: Bill Trotter] #1294357
Fri Jan 11 2019 03:05 AM
klhansen  Offline
Eagle River, Alaska
I'd guess about 10-12 along both the front and back. I could go count them on mine, but that's probably pretty close.
Re: 37 Chev 1/2 ton stake pocket removal [Re: klhansen] #1294358
Fri Jan 11 2019 03:13 AM
Iron River Mi.
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
