The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
13 members (Johnny N, buoymaker, Hotrod Lincoln, coilover, Aub1953, Achipmunk), 90 guests, and 4 robots.
Forums47
Topics117,741
Posts942,031
Members43,035
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 3 of 4 1 2 3 4
Re: NEW!!! 3:55 Gear Installation Technical Article
SWEET #1217351 Mon May 15 2017 04:16 AM
Chris, I'm planning to do this same gear swap on my '46.
Where did you get the tools for adjusting the notched nuts to get R & P backlash? The GM Rear Axle Overhaul manual shows the tool as J-972. Thanks.
1946 1/2 Ton Pickup
SWEET #1217369 Mon May 15 2017 06:14 AM
I hand made a tool using steel bar stock and a couple of bolts.
My TRUCKS website
SWEET #1217377 Mon May 15 2017 01:48 PM
Very large 90* bent long nose pliers works great for the adjustment as quick one time solution.
Homemade tool with properly spaced pins is another option as mentioned.
SWEET #1217387 Mon May 15 2017 02:36 PM
ace skiver
Here is the. tool. I'll ship it to anyone who sends a $50 deposit refunded when the tool is returned (less shipping cost).
Maybe someone closer to you has a tool. Patrick's used to provide the tool in his installation kit, but he has become increasingly less reliable.
The tool is in Classic Parts' installation kit.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
SWEET #1217420 Mon May 15 2017 06:42 PM
As a side note on the rear gear install kit.
My orginal rear gears were in good shape. I reused all the bearings. Having a selection of pinion shims and the spacer tool was all that was needed. Made the spacer tool from the pattern supplied on Deves.
SWEET #1294099 Wed Jan 09 2019 04:31 AM
Moderated
Nothing like being in the middle of a post and the screen goes blank . "As I was trying to ask . In the tech article you(sweet) removed the brg, seal,and "deflecter'' .Well I did same only with 2 days of hell . The washer (deflecter) got bent a lot . What is it for ,do I need ? Could I just fix it up a little and put it back In with new brg. and seal ??? I do not know how to get a pic to you .
SWEET #1294243 Thu Jan 10 2019 03:01 PM
Last week I rebuilt the torque tube assembly by using this Technical Article and Deve’s website. Both of these resources are excellent and between the two I took the brave step of attempting this. Whitelightening: believe me when I say if I can do it - you can too. Not sure if I would have attempted this rebuild without SWEET’s good work.
Bout’ the only thing I would add is the front bearing lock ring can be tricky to slip into place. I took some extra time and ensured this ring was smooth around the outside edge, and I ensured the same for the torque tube. A very light coat of white grease on these two mating surfaces helped to let this ring slide into place with light taps on the pinion gear.
SWEET #1294271 Thu Jan 10 2019 05:47 PM
ace skiver
Congratulations, Tom
Tim
SWEET #1294277 Thu Jan 10 2019 06:33 PM
Patrick Dykes used to imply that he was the exclusive supplier of these 3.55 kits for Chevy/ GMC 1/2-tons. I thought it was his design. Do other parts sellers offer these gear sets? I wonder who actually makes them.
Professional Novice
SWEET #1294328 Thu Jan 10 2019 11:50 PM
ace skiver
At one time, Patrick Dykes was the only supplier.
One of our members, Mother.Trucker, has also been a supplier for several years.
MT obtains his sets on his own, from a (foreign) manufacturer.
One photo below shows boxes of those R&P stacked to ceiling.
Tim
Page 3 of 4 1 2 3 4
Moderated by  SWEET
