The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 registered members (Charles in CA, Hotrod Lincoln, BC59, joe apple, Eureka Jim, 1 invisible), 292 guests, and 3 spiders.
Forums47
Topics116,143
Posts923,579
Members42,356
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Tapping Threads Into the Crank #1294216 Thu Jan 10 2019 04:55 AM
Lugnutz Offline OP
I decided to press fit the HB on my freshly rebuilt 1963 230ci (as opposed to tapping it onto the crank snout.) I've tapped them on using heat and a hammer before, but thought it was time to try a press fit.
Every 230/250 I own has a blind crank snout (no threads or bolt).
I bought a kit from Jerry (Hot Rod Lincoln) that is designed to accurately tap threads into the crank snout so you can press fit the HB. I'm happy to report that it works great. I did two cranks tonight. First, I did a trial run on a 1972 250ci that has seen better days. That went smoothly. Next, the 1963 230ci. That went faster since I had already done one. Here is a step by step for those who like pictures. Jerry's kit is top notch. The kit is shown in the first picture. LINK HERE
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1294232 Thu Jan 10 2019 01:48 PM
2-Ton Offline
That does look like a slick setup!!
Don
"The Flag Pole"
More pix on Photobucket
'46 2-Ton grain truck
'48 3/4-ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
'70 American LaFrance pumper fire truck.
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1294238 Thu Jan 10 2019 02:16 PM
sstock Offline
Yeah, I'm on his list to get one of his kits, every detail right down to the bearing, I've seen guys snap off their 7/16" bolts not using a proper installer.
1953 Chevrolet 3100
261 cu inch, sm420, 3.55 rear, omaha orange, still 6 volt, RPO green glass, side carrier spare
https://www.youtube.com/watch?v=Bli...n05i04t1aokgm4p04jiwgffwhyyih5xbk0h00410
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1294460 Fri Jan 11 2019 10:53 PM
drdoug Offline
Very nice looking kit. Thanks for the link to the photos.
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1294486 Sat Jan 12 2019 02:41 AM
42465967 Offline
DLBrooks
dang!
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1294651 Sun Jan 13 2019 01:47 AM
Happy Birthday EdPruss Offline
Great kit, notice the installing arbor threads into the crank with the 7/16-20 threads, the acme threads pull the balancer into place, the 7/16-20 threads are not designed for that load, make sure to use HRL's arbor for this.
Ed
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1294653 Sun Jan 13 2019 02:12 AM
42465967 Offline
DLBrooks
Ed, ok but what would be the diff if I used a longer grade 8 7/16x20 bolt then push it on with a 7/16x20 nut suitable washer. I do agree that HRL has a good design and tool.
You're saying just do not pull it in with the crank threads, correct?
Re: Tapping Threads Into the Crank [Re: 42465967] #1294684 Sun Jan 13 2019 05:44 AM
klhansen Online
Originally Posted by 42465967
Your saying just do not pull it in with the crank threads, correct?
Yes, they are not designed for a load like that. Static loading is OK, but when the bolt is heavily loaded and then turned, the crank threads will likely strip off or shear.
First car '29 Ford Special Coupe
#2 - '29 Ford pickup restored from the ground up.
Newest Project - 51 Chevy 3100 work truck. Photos
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1295008 Wed Jan 16 2019 12:34 AM
Hotrod Lincoln Online
Boltergeist
Since the hole in the front of the balancer is just over 3/4" in diameter, the 3/4" ACME thread just keeps the thrust centered a little better. A 3/4" V thread and a nut and flat washer, or even a piece of 7/16-20 all thread would do the same thing as long as the threads in the crank snout remain stationary- - - - -the ACME thread and the banded ball bearing just make it look a little less shade tree!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Tapping Threads Into the Crank [Re: Lugnutz] #1295258 Fri Jan 18 2019 04:33 AM
delux54panel Offline
Beautiful setup! Is it for rent, or sale only? Also, can this job be done with the engine in the truck?
Thanx,
Marty
Page 1 of 2 1 2
Moderated by  48bigtrucks, MNSmith
Powered by UBB.threads™ PHP Forum Software 7.7.3
