New Forum Added in Parking Lot
EARLY BOLTS
1916 - 1936
1928 Chevrolet AB Canopy Express "Justin"
Discussing issues specific to the pre-1937 trucks.
Forums64
Topics122,558
Posts989,211
Members46,963
Most Online1,229 Jan 21st, 2020
#129339
Fri Jan 04 2002 04:56 AM
OP
I am looking for a tilt column out of a old chevy van with the ignition on the dash. If you have one or know of one let me know I'd appreciate it. Thanks, Chad
DRIVE IT LIKE YOU STOLE IT !!
#129340
Sat Jan 05 2002 05:33 PM
They are out there but I've never been able to find them actually in the vans.....I normally buy them at swap meets usually between 100-150 ea. Last swap meet I went to a guy had 3 of them for sale and I bought all 3 at $100 ea for projects and customers vehicles. When you find one be sure to check the signal housing where the signal lever goes and where the cancel springs are for broken or missing parts. Check the tilt for smooth operation and if it doesn't have the neutral safety/back-up switch try and get it for less but don't set it down if your at a swap meet because I might be right behind you and buy it
Joe
#129341
Mon Jan 07 2002 12:13 AM
Another column that might work for you is a **** van up to 79.They are easier to find, had no switch, and the tilt and siglal handle are combined. This cleans things up nicely. If you dont tell, nobody will know it's brand x
