EVENTS
Check in for status!
Jump over to the
Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Forums50
Topics122,129
Posts979,674
Members44,158
Most Online1,229 Jan 21st, 2020
 block fitting for oil gauge line--big mess??
OP
I'm backdating the gauges on my '48 GMC 1 Ton and need to change out the oil fitting at the block that supplies oil to the gauge as well as to the oil filter. There is a 90* brass fitting that threads into the block with one outlet feeding the gauge and the other outlet going to the oil filter. The oil filter connection will have to be removed first and I'm wondering how big a mess I'll be making when it's disconnected. I'm guessing the outlet to the gauge would only leak out under pressure but I could easily be wrong. What should I expect? Thanks, Jim
 Re: block fitting for oil gauge line--big mess??
All you can expect will be a little drip unless you or someone starts the engine. Then you will have a big mess. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. [url=http://www.stovebolt.com/gallery/capito%20george%201956.html] 1972 Chevy c10 Cheyenne Super
Boltergeist
Put a couple of rags under the fitting to catch the drips. There won't be much, but the line going to the oil filter will dribble enough to make a mess unless you raise the end of the line above the level of the filter housing. If you pull the top off the filter canister and remove the element first, there will be a lot less mess to deal with. Jerry
The murder victim was drowned in a bathtub full of Rice Krispies and milk. The coroner blamed the crime on a cereal killer! Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
OP
Hahaha George, even I know better than that! And thanks, Jerry, I didn't think of removing the element but I will now. I'm always learning something new on Stovebolt.
