The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
11 registered members (Barnfind49, Gary P., 47PUJim, HandyAndy, five-oh, Chasz), 307 guests, and 3 spiders.
Forums47
Topics116,116
Posts923,323
Members42,345
Most Online940
Apr 5th, 2017
Image Posting Policy
1950 3100 radio light #1290447 Sun Dec 09 2018 10:49 PM
Jhyp Offline OP
How do I replace the light bulb in my radio? Do I have to remove the radio from the dash to replace? Help.
Re: 1950 3100 radio light [Re: Jhyp] #1290556 Mon Dec 10 2018 08:03 PM
truckernix Offline
You definitely will have to remove the radio. My memory for the details have faded a bit but I think at least one of the AD radio models has a light on a bar that can be removed from the back.
1951 1 Ton Completed
Re: 1950 3100 radio light [Re: Jhyp] #1290599 Tue Dec 11 2018 01:14 AM
2ManyTrucks Offline
hi Jhyp,
truckernix is correct, there is a tab to pull the light out with it's socket assembly.
you pull straight back on the tab about 1/4 inch to unlock it, then it sorta twist and giggle and work it out of the unit, it will come with 1 wire, it grounds to the chassis.
i included views so you have an idea what it looks like in there
i have contemplated if it is possible to replace this bulb without removing the radio, it might be... in theory
if you can undo the two housing screws on the bottom, the whole back will slip off without removing the radio from the truck, this perhaps is possible to then change tubes and this bulb.
i haven't had to go back into my radio since installing it yet
let us know how it goes
thanks
-s
1430s, 1420, 9430
-2MT
Re: 1950 3100 radio light [Re: Jhyp] #1290677 Tue Dec 11 2018 04:59 PM
Jhyp Offline OP
Got the back off the radio (without removing the radio) but can't see the dial light. And no tab that I can see. Will continue to explore.
Re: 1950 3100 radio light [Re: Jhyp] #1290957 Thu Dec 13 2018 07:42 PM
truckernix Offline
There are two models, the"slant cover" one and the straight back one. I think the one shown is the slant cover one.
Moderated by  truckernix
Powered by UBB.threads™ PHP Forum Software 7.7.3
